TXRaptor
- Joined
- Sep 15, 2010
- Posts
- 1,851
- Reaction score
- 1,044
I have deaver +3s and I still use the roadmaster helpers whenever I tow. ( 3500 lb hot rod on a 2600 lb 20' deckover featherlight.)
You'll also still want some sort of mechanical sway control. Perhaps just try the roadmaster kit ( it is $399 IIRC), before you drop 1500 on bump stops, 1425 + shipping on deavers, Whatever the geisers cost, etc etc etc.
I've used the roadmaster kit on 2 f-150s since 2011. They still work just how they did when new. I used to have them on my 2011 EB screw, with which i towed every bit of 10,000 lbs with through the smoky mountains regularly. ( gooseneck featherlight with a 66 galaxie r code and a 2005 Ford GT on it)
I looked at the Roadmaster Active Suspension and it seems like an excellent way to add stability to the truck when towing. How much does your truck sag when using the Roadmaster and Deaver +3s?
https://activesuspension.com/
For my Gen 1, I had a SuperSpring Add-a-Leaf on top of my leafs, but it was a lot more work to install. My SCAB would drop down less than an inch with a 4500 lb trailer and it towed great even at 80+ MPH.
On my Gen 2, I want to keep the nice ride with Geisers and standard Deaver +3s for 90% of the time. I will use the Roadmaster for the 10% when I am towing and remove them when I am done.
