FOX 3.0 Shocks Is there a break in period? These shocks are too tight!
JetDriver480
I dropped my tires down 10 PSI (Toyo M/T's) and the ride significantly improved. Not a cadillac but damn nice for a truck.
Jtnuge
Im lowering mine tomorrow. The read out was stating 47 ish. The door jam I do believe is a lot lower. Why are they over inflated from the factory of dealer? Not sure who had there hands involved here,lol. I usually go off the door jamb, just have forgotten to play with the pressure so far. Just two weeks old.
Cleveland
I let some air out and quite a bit from 44psi. The door jam says 38psi. I brought it down to 40 psi since my tire gauge could be a little off. Went for a ride and they read 42 on the display. After they cool they should be close to the 38 psi.
Deleted member 12951
Mine were at 46 from the factory!
It took a LOT of air out of those big tires to come down 8 psi!!!
Get one of these. Goes down in seconds and great for airing down further when off-roading.
Jtnuge
I put mine down to 42 tonight. Will see how it rides in the morning. At times it rode similar to my 2012 reg cab stx did. Hopeful this will help some. If not I still can go to the door jamb psi.
