GEN 2 eibach front spring install
halogrinder
halogrinder
34 7/8 on the drivers side, and slightly lower on the passenger side.
I'll re-measure when I drive it/park again on level ground, possibly the slight turn to the left caused the biased lower right side.
Carbon8
Interesting that our heights appear to be the same even though I still have my RPG spacers installed as well.
Have you done anything to the rear? Can you measure the rear for me as well. I have deaver+3 with about 300lbs in the bed and am at 16 3/4 (top of wheel).
Thanks.
halogrinder
halogrinder
Thanks.
stock suspension otherwise. Sure. I'll go straighten it out and get another front reading when i go do a deposit later today
Carbon8
Can you actually do all 4 measurements from center of wheel to fender. You don't have beadlocks so I'm getting a 1.25" discrepancy because of the beadlock ring. I know it's hard to get perfectly center but should be a better representation.
