Does the Supercrew have different rear leaf springs then Supercab?
byz250f
I was told the super crew has a different leaf spring then the super cab on the gen 2 truck. Anyone know if this is true?
Sitdown
Suburbia, IL
While they may in fact be different PN and rates, the difference is really negligible. This was a debate on the Gen1s as well, and i really couldn't find actual specifics documented other than someone talked to a fox/insert shock company X and they are stiffer/etc to factor additional weight.
I added brand new screw takeoffs to replace my tired scab shocks. I thought maybe they felt stiffer, but any new shock will feel that way when replacing beat to hell 40k mi units. Any added stiffness is only a positive IMO if you plan to use the truck. Same would apply for leafs in similar fashion
B
byz250f
Im worried about opposite scenario if Im going to tow at all that using SCAB springs on a SCREW that it will squat or be to squishy in rear.
