Deaver +2 & SVC Bumpstop Kit
guernsej
I doubt it's come up yet, but anyone have experience with Deavers voiding the warranty on other rear suspension components?
I got the factory extended maintenance plan specifically to cover the shocks.
joey185
Can they be adjusted all the way to the axel so that if your had to tow something heavy that it would keep rear end up?
TXRaptor
Not sure about the SVC bump stops, but RPG has a longer extension you can use for "towing" purposes. However, most Raptor performance shops do not recommend you use your bump stops for towing stability, as that is not what they were designed to do.
You can add SuperSprings or Roadmaster Active Suspension on top of your leafs for the times you are towing. They both would need to be removed when doing heavy off-roading if you want to flex the suspension to its limits. (As would the longer bump stop extensions)
https://www.supersprings.com/shop/ssa28/
https://activesuspension.com/products/kits/2010-2016-ford-raptor/
The Roadmasters are easier to install and remove.
svc
Worldwide
That is correct, never overload factory capacitys of corse but the bump can be lowered to act like an air bag on rd
-J
