GEN 2 Best Lift Option - ReadyLIFT or Perch Collar?
TRIO
Hey Fellas,
I'm looking to do a leveling kit (plus Wheels/Tires) on my new truck and was wondering what the best option is for a lift.
It seems to me that the Perch Collar would add some additional compression/tension to the suspension and effect travel & handling.
The ReadyLIFT option would attach to the top of the assembly and not effect the function/travel/handling at all.
Am I totally off base here or is there some truth to my though process?
Also does 2.5 inches perfectly level the truck? I measured from ground to top of wheel arch on the front and rear wheels and the difference was 2". Would the 2.5" option give it a higher front end?
Thanks!
Aaron
Meme Corps Commandant
WA
Perch collar. the other option will allow more droop than your suspension is designed for.
/thread
xrocket21
Maine
Hey Fellas,
Thanks!
You are off base, and youre theorizing is incorrect. A collar doesnt add addition compresson/tension, it basically moves the location of the bottom of the spring, raising height, and does not affect travel or handling.
T
TRIO
Thanks for the feedback.
Any thoughts or reports from anyone using the eibach Pro-Lift kit?
Aaron, I'm laughing at your Terrain Mode pic. That's freaking funny! Hahaha
xrocket21
Maine
Eibach looks a little front high to me
Guppy
IL
I'm going to try the ready lift 1.5" to space the shock from the mount.
This should not have any impact on the factory ride.
May not get as much lift on the front as some desire.
But anything compressing the spring is going to change the ride.
Has anyone already tried this?
MattHamby598
Atlanta
I just got a 19 three weeks ago and had it leveled the first week with a ready-lift(before joining here and reading about the truck) I’m not a fan of the ride and plan to do the collars next week.
