Stainless Works downpipe and exhaust review
k-rub
Tucson, AZ
So the downpipes with high flow cats and catback exhaust were delivered last week. Initial impressions were everything looks high quality: welds, connections, adapters etc. Downpipes and catback came in two different boxes. Make sure you read the directions in their entirety. It will save you some time if you skip steps.
The downpipe box came with a stud removal socket, bolts, clamps, and O2 extension wiring. The original O2 sensor clip is hard to reach from under the truck so the extensions help out greatly.
If you get the downpipe kit check the O2 extensions they send you. They sent me the wrong ones. You’ll need ones with 4 pins and they sent me ones with 5 pins. I called SW and they overnighted me a new set of extensions.
The catback box comes with everything for installation aside for one factory clamp you will reuse.
The downpipe installation was rough and took a while. I’d say ¾ of my time was spent on the downpipes and the rest of the time was installing the rest of the exhaust.
I would definitely recommend watching Muredhawk’s video for turbo adapter removal. I bought the stud removal tool he recommended and a butane torch. The studs came out no problem. I also used PB Blaster on all the bolts and had no issue loosening them.
http://www.fordraptorforum.com/f261/spd-turbo-adapter-install-easy-way-video-54742/
The truck sounds awesome now! I’ve had multiple neighbors comment how they like the sound. It is pretty loud but not obnoxious loud. Idle sounds like a mini Cummins diesel.
Since the exhaust tips are adjustable I initially tucked them more under the bumper. This made exhaust noise seem louder than it should inside the cab because the sound was reverberating underneath the bed. So I pulled out the tips and used exhaust wrap to wrap the pipes from the downpipes back. The difference in sound is incredible. The loud noise inside the cab is gone and I can enjoy the exhaust now. I live in AZ so I really don’t worry about corrosion, but I’ll eventually coat the wrap with silicone sealant. I do go off the beaten path from my local Starbucks so I’ll see how the wrap holds up over time.
I have the 5 Star Tune with N Gauge as well. Right now the truck is still throwing codes about the high flow cats. I called 5 Star and they said SW moved the O2 sensor positions. I should have a new tune in the next few days addressing it. EDIT: New tune fixed the codes.
There is a noticeable difference in power with the tune and exhaust setup. The shift points and throttle sensitivity is much better than before.
And a buddy down the road with a Roush S/C Gen 1 gave it his stamp of approval.
Warmed Up Idle Video
https://youtu.be/vALu66-mMak
Quick warm startup and rev video
https://m.youtube.com/watch?v=q0R5G3dlhFY
EDIT: Quick driving clip on the dirt in Baja mode. Turn the volume all the way up. Sounds pretty good. I've got the Full Race I/C and CAI, Stainless Works exhaust/DP, and 5 Star tune running 91 Street.
https://www.youtube.com/watch?v=xsdoPitgYWc
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
Good write up man! This is the setup I want after the warranty expires.
K
k-rub
Tucson, AZ
Heres a short clip warm startup and rev
---------- Post added at 10:47 AM ---------- Previous post was at 10:46 AM ----------
Good work. I assume you removed the pipes to wrap them?
Unfortunately no. The wrap idea came about after installation and i just wrapped them in place. Didn't want to disassemble it again. I would definitely wrap when they aren't on the truck if they did it again.
chi_weezy
Well-Known Member
Ha it does sound like a little diesel. You keeping the chrome tips? Post some clips of fly bys and acceleration!
K
k-rub
Tucson, AZ
At first I was dead set against them. They are growing on me a little bit now. I'll wait a bit and see what happens.
I'll def get some more videos as soon as I can. Need to find a cameraman. I'm going to do the other vids in the dirt because......that's just the way it should be.
Azholley
Peoria, Arizona
Come up from Tucson and I'll be your cameraman lol
Jayrod
FL
Since the exhaust tips are adjustable I initially tucked them more under the bumper. This created extremely bad drone because the sound was reverberating underneath the bed. Inside the cab the drone was bad. So I pulled out the tips and used exhaust wrap to wrap the pipes from the downpipes back. The difference in sound is incredible. The drone is gone and I can enjoy the exhaust now. I live in AZ so I really don’t worry about corrosion, but I’ll eventually coat the wrap with silicone sealant. I do go off the beaten path from my local Starbucks so I’ll see how the wrap holds up over time.
I'll get better videos in a few days. There's a rattle I need to narrow down and fix.
K-Rub,
Want to make sure I understand you. This system droned until you put the exhaust wrap on? I am doing down pipes only so I am just curious.
