Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2]
SPD turbo adapters and Kooks catted downpipe install tips/help
This is a discussion on SPD turbo adapters and Kooks catted downpipe install tips/help within the Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
You kinda need a real torch to get the proper heat and accuracy to do it properly. A handheld map ...
Like Tree1Likes
Old 07-12-2018, 07:21 AM   #11 (permalink)
xrocket21's Avatar
You kinda need a real torch to get the proper heat and accuracy to do it properly. A handheld map gas torch will heat to broad of an area.
Also, you want a chuck style stud extractor.
I couldn't get mine out first try and had to button it back up. took a second attempt with a real torch and did it in like 2 hours, including dropping the tranny cross member.
edit:
I took pics and commented here
I installed SPD exhaust adapter this weekend myself
xrocket21 is online now   Reply With Quote
Old 07-12-2018, 09:35 AM   #12 (permalink)
Guy
The SPD adapters didnít do a darn thing for me. They werenít that bad too install, but they didnít add even a .1 to my 0-60 time.
Just my two cents. I wouldnít have bothered if I had to do it over again.
Originally Posted by Onemoosehorn View Post
Thanks. Iím going to pick up a bottle of Mapp gas to use. I believe thatís the yellow bottle. Iím hoping they arenít to bad with only 3600 miles on it.
Guy is online now   Reply With Quote
Old 07-12-2018, 09:42 AM   #13 (permalink)
edit:
Thanks for the link. I have the extractor that SPD sends/recommends. It looks like it should do the job.
---------- Post added at 09:42 AM ---------- Previous post was at 09:40 AM ----------
I figured if I was changing downpipes I would change the adapters also. Seemed like they were pretty good cost wise for the HP gain they claimed.
Do the nuts come off the adapter downpipe side pretty easy?
Onemoosehorn is offline   Reply With Quote
Old 07-12-2018, 01:51 PM   #14 (permalink)
remove the trans cross member, you might have to remove a heat shield for clearance at reassembly also.
the stud extractor isn't worth a darn, use one of those sockets that tightens up as you twist it, latches and tightens onto anything.
heat for sure.
Higgs Boson is offline   Reply With Quote
Old 07-12-2018, 02:41 PM   #15 (permalink)
xrocket21's Avatar
The nuts came off very easy, not a problem. It is the steel stud into the cast turbo housing that's the problem. I tried to do mine at like 500 miles hoping it would help and it was still in impossibly tight without a torch. With a torch, the studs came out fairly easily.
you do NOT want to break a stud off in the turbo housing.
Also, you will destroy the old studs when removing them.
SPD adapters has an outlet of 2.3125" ID compared to the stock outlet which is 2.0625" ID.
Old 07-12-2018, 04:56 PM   #16 (permalink)
heat for sure.
That’s the kind of extractor I bought. That’s what they recommend/include now for an extra $25. I bought the stud kit also.
Old 07-12-2018, 05:12 PM   #17 (permalink)
the one I am talking about is a snap on socket, the one that was included did not get a good grip, unless it's new like 2 weeks or less. :-) if so, that's awesome!
Old 07-12-2018, 06:02 PM   #18 (permalink)
Ok Iím not sure then. This is the exact one they sent me.
TITAN - 16023
Old 07-12-2018, 06:08 PM   #19 (permalink)
that's the one that came to me also, it was too big to get a good grip. here is what you need, it's a 3/8 roller bearing stud remover.
Pyro3601 likes this.
Old 07-12-2018, 06:39 PM   #20 (permalink)
Thanks. Iíll look into that one.
Borla S type + Kooks dp + Spd turbo Adapters awc557 Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 26 Today 07:54 AM
Stainless Works Catted Downpipes vs SPD Turbo Adapters TXRaptor Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 9 05-10-2018 12:55 AM
Downpipe & Turbo adapters Msb.19d Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 2 10-03-2017 12:22 AM
GEN 2 KOOKS Downpipe to KOOKS side pipes RyleM Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 1 09-06-2017 08:01 AM
GEN 2 Kooks Catted Downpipe and Borla S-Type and SPD video Bullishone Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 85 08-07-2017 01:36 PM
