Pedal Commander - WOW
tmd11111
You must not know how this works. It is well documented here (and other places) how this improves 1/4 mile and 0-60 times.
I know exactly how it works. Any documentation showing improved 0-60 or 1/4 mi times are purely marketing tools. If you actually believe it then their marketing team was successful
MGD
Banned
Like I said, there are posts showing empirical data with a marked improvement. If you have any interest in buying, or have an axe to grind, those will be the proof you are seeking.
@smurfslayer has some 0-60 times I believe.
mmacfn
mmacfn
Show low, AZ
If pedal response time is faster then by definition doesnt it have to improver 0-60?
tmd11111
Driver response time and vehicle performance are two different things. It’s not going to make the truck or any other vehicle faster. Learn to drive
MGD
Banned
You are not understanding. The factory drive by wire limits the amount of pedal you have. The PC greatly increases that pedal travel so that you can tap all the power of the engine. The factory settings really limit it.
Smokeshow60
SgtMajor of the MemeCorps
Southern Ohio
Lol.... wrong. But I'm sure your use to that.
MGD
Banned
Smoke - what do you think it is? How do you explain the better 0-60 times? Go ask @smurfslayer. Those who have the PC report the better 0-60 times. I am not sure what you folks are missing... this is very straightforward.
tmd11111
Are you for real? Buying your own ********. The PC don’t increase pedal travel in any way shape or form. It controls the speed that the throttle body opens. Fully open is fully open. It only opens it faster. Nothing more, nothing less.
Smokeshow60
Southern Ohio
There are no limitations removed by a pc. No increase in "pedal travel" as you stated (whatever that is) . No additional power, no additional torque. Pc only modifies the pedal sensor input to throttle duty cycle ratio. Period. Any difference in actual performance i.e. 0-60 times etc. are the results of different driving inputs or external conditions including adaptive strategy programming and heatsoak. WOT is WOT in both applications.
