Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2]
Opinions:. Whipple stage I
This is a discussion on Opinions:. Whipple stage I within the Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by MadRaptor65 Just dropped my Raptor off at Whipple so they can install Tune. I am suppose to ...
Like Tree13Likes
Old 06-19-2017, 07:04 PM   #41 (permalink)
Originally Posted by MadRaptor65 View Post
Just dropped my Raptor off at Whipple so they can install Tune. I am suppose to get a copy of the Dyno. The one they did in Feb. is RWHP and RWTQ.
Stock pull. At 66 deg, it pulled 359.18 RWHP @ 5,200 rpm / 372.93 RWTQ @ 4,850 rpm.
If they allow me to share new Tune Dyno chart I will. Hope to pick my truck up Tue. afternoon or Wed. morning.
Right on... I hope they're cool with you posting it, 'cause I'm certainly excited to see it! :-)
pughde and MadRaptor65 like this.
BurnOut is offline   Reply With Quote
Old 06-21-2017, 04:27 PM   #42 (permalink)
Been following, any updates?
cobra281 is offline   Reply With Quote
Old 06-22-2017, 05:10 PM   #43 (permalink)
DrifterGTR's Avatar
followed
DrifterGTR is offline   Reply With Quote
Old 06-22-2017, 09:49 PM   #44 (permalink)
SOAKINRED's Avatar
Following
SOAKINRED is offline   Reply With Quote
Old 06-22-2017, 11:39 PM   #45 (permalink)
KWT
following..
KWT is offline   Reply With Quote
Old 06-24-2017, 04:41 PM   #46 (permalink)
I know we're all busy, but I've noticed a trend of people that are going to post updates after a mod with zero updates... These posts start off strong but the finish, meh....
Old 06-24-2017, 11:27 PM   #47 (permalink)
Yeah it's like 2010 all over again. People were so hungry when the gen1 came out people would follow anything.
zsommer79 is offline   Reply With Quote
Old 06-26-2017, 12:27 PM   #48 (permalink)
Originally Posted by DrifterGTR View Post
followed
Originally Posted by SOAKINRED View Post
Following
Originally Posted by KWT View Post
following..
Hey guys, sorry for not responding sooner. When I pick my Truck up last week. I was told by Whipple Tech that in this heat wave. I would not feel the improvements. He was correct. (see Attach on Temperature and Air intensity)
I took my Truck on a road trip to Oakhurst CA. around 4pm. There was not much low-end TQ. I did a manual shift going up steep grades. I put it in 7th gear and the power was flat until around 4000 rpm's. The Truck took off through 8th. I didn't keep pushing because of traffic but the power curve was at high rpm's. Reading the Temp. density report it did make sense because in high heat the Turbo must spool faster to create power. I had an early morning appt. today. It was in the low 80's. The low-end TQ was back. I floored it, the Turbo gauge maxed out over 20 psi and broke tractions real hard 1st to 2nd and 2nd to 3rd. It will be in the mid to low 90's this week so I will drive this week and give feedback at the end of the week or early next week. Once again thanks for your patience as I learn about Heat and Turbos. see attach Turbos and Temperature.
Turbos and temperature €“ summer weather and turbocharger performance | AET Turbos
MadRaptor65 is offline   Reply With Quote
Old 06-26-2017, 06:19 PM   #49 (permalink)
DrifterGTR's Avatar
I took my Truck on a road trip to Oakhurst CA. around 4pm. There was not much low-end TG. I did a manual shift going up steep grades. I put it in 7th gear and the power was flat until around 4000 rpm's. The Truck took off through 8th. I didn't keep pushing because of traffic but the power curve was at high rpm's. Reading the Temp. density report it did make sense because in high heat the Turbo must spool faster to create power. I had an early morning appt. today. It was in the low 80's. The low-end TQ was back. I floored it, the Turbo gauge maxed out over 20 psi and broke tractions real hard 1st to 2nd and 2nd to 3rd. It will be in the mid to low 90's this week so I will drive this week and give feedback at the end of the week or early next week. Once again thanks for your patience as I learn about Heat and Turbos. see attach Turbos and Temperature.
Water/Meth injecton would help lower the air charge temps and boost power a bit. But another less expensive option is just to mist the intercooler with water. Between that and the evaporative cooling of the air passing over it while driving that should significantly reduce the intake air temps. I used to do this on a few imports I had while stationed in AZ back in the day.
MadRaptor65 likes this.
Old 07-17-2017, 06:10 PM   #50 (permalink)
Where does the intercooler mount....can find any info or pictures...
Does it replace stock position or is it moved up like the Full Race/ADD one.
Thanks.
racerjb is offline   Reply With Quote
2013 Ford Raptor Whipple Stage 2 CBHolman Ford Raptor For Sale! 45 03-26-2018 02:30 PM
2013 Raptor Screw - Tuxedo Black - Whipple Stage 2 Kit BeastRaptor Ford Raptor For Sale! 10 08-22-2017 09:29 AM
2011 Raptor - Problem with Whipple Stage II Going Lean radelow Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 4 12-29-2016 11:17 AM
FS: AFE stage 2 Cold air intake stage accely Garage Sale 4 02-15-2016 12:27 PM
Thinking about mounting a Stage 2 Whipple kit, looking for information. ivo1.cox Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 10 09-01-2015 04:40 PM
