No Tips for me!!
mikepipe597
All,
Looking for additional options and suggestions for an exhaust that dumps down after the muffler. No rear tips no side tips. So far the only option I've found is the Stainless Works. Does anyone have any other ideas? Not looking for a great sound or look. This is for ground clearance issues only.
Thanks
reaper1441
isn't there a magnaflow kit that's just a muffler and a turndown?
nope just stainless works.
Nick@Apollo-Optics
Other than a custom exhaust, the Stainless Works kit is the only system on the market that has a true under the truck dump. If you'd like to go with that kit, or explore some other options that you could pair with a custom exit, please let us know and we'd be happy to work with you.
Aaron
Meme Corps Commandant
WA
A lot of Gen1 guys just decided to Forgo the tips and cut the exhaust where it rolls over the axle. Nobody is going to see the tips anyway, and you're doing it for function, so why worry?
Jake17
★ REBEL LIFE ★
modified Flowmaster FlowFX...sounds f'n sweet
Sitdown
Suburbia, IL
Most of the kits offred are easily coverted to dump style. The pipes in the kits from the muffler to connect to factory tailpipes bend up. Simply turn them down, cut where you like the turn down to finish. Same process for stock, except you need to cut/clock/weld
Stock
6990601F-47CE-4EF7-A0A5-C3CF6F0A94E8_zpsnz3bv9ji.jpg[/URL]
Corsa
EFEF6FA1-EC68-46AB-A39C-A6AD28C8DD80_zpsogooqcde.jpg[/URL]
