Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2]
Misfire Code? SPD may have found a simple fix.
This is a discussion on Misfire Code? SPD may have found a simple fix. within the Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
SPD Performance has fixed the misfire code issue on 2 trucks. We replaced the factory spark plugs with Motorcraft SP542 ...
Like Tree5Likes
Old 10-12-2017, 06:06 PM   #1 (permalink)
Junior Member
Default MISFIRE CODE? SPD Performance may have found a simple fix.
SPD Performance has fixed the misfire code issue on 2 trucks. We replaced the factory spark plugs with Motorcraft SP542 (cold plugs) which we spaced at .028.
Installing time is 30-45 minutes. SP542 plugs MUST be respaced to .028 - .030, but make sure they are all the same spacing. They will come in with a larger spacing.
P/N SP542
Ford P/N CYFS092YPT
6 spark plugs are required.
This misfire code seems to happen more frequently after installing aftermarket intake systems but has also plagued 100% stock trucks as well.
Hope this helps you guys. Please send me feedback to [email protected].
JacobSPDPERF is offline   Reply With Quote
Old 10-13-2017, 08:43 AM   #2 (permalink)
Junior Member
Step #38 From the whipple stage 1 kit also states to close the spark plug gap to .025'' should this should be done no matter what or only if mods are done to produce more air flow.
Remove factory spark plugs. Close the stock gap to .025. Failure to close the gap may result in horsepower variance and possible misfire.
slaughter is offline   Reply With Quote
Old 10-13-2017, 10:04 AM   #3 (permalink)
Junior Member
SP534 spark plugs are running too hot.
The closest we are gapping tuned 11-16 ecoboost trucks are .026. The coils on the 2017-18 Raptors are better so a gap of .028 on the SP542 would be fine.
Old 10-13-2017, 12:02 PM   #4 (permalink)
WhatExit?'s Avatar
Thanks!
Yet another reason not to buy a "Cold Air" Intake (CAI) system
Mcnawsty likes this.
2017 Magnetic SuperCrew Cab 802a; Raptor Tech Pkg w/Adaptive Cruise; 17" Forged Aluminum (Beadlock) Wheels; 2nd Row Heated Seats; Moonroof; Tailgate Step; Exterior & Hood Graphics Pkgs (both removed); Carbon Fiber Pkg; Engine Block Heater. Added: new V1; BlendMount; XPEL Ultimate & Stealth Film; Tinted Front Windows; BedRug, Roll-N-Lock A-Series bed cover
WhatExit? is offline   Reply With Quote
Old 10-15-2017, 02:58 PM   #5 (permalink)
Junior Member
Whipple does extensive testing and they say .025. Guess it’s each his own.
Old 10-25-2017, 10:43 AM   #6 (permalink)
Junior Member
Originally Posted by slaughter View Post
Whipple does extensive testing and they say .025. Guess its each his own.
Tuners will gap the 11-16 F-150 3.5 to .025 when they are pushing 21-22psi of boost. This prevents spark blow out.
The 17-18 Raptors have stronger coils. Gap of .028 will work for a stock or tuned truck.
Old 10-25-2017, 11:07 AM   #7 (permalink)
EricM's Avatar
More details please on the coil change. Tasca parts lists the same part number for a 2015 3.5 EB and a 2017 3.5 Raptor EB ignition coil. BL3Z-12029-C. Same price as well.
2015 EB: https://www.tascaparts.com/auto-part...on-system-scat
2017 HO EB: https://www.tascaparts.com/auto-part...on-system-scat
2013 Tux Black SuperCrew.
Nobody gives a crap where your post was sent from...
EricM is offline   Reply With Quote
Old 10-25-2017, 04:09 PM   #8 (permalink)
Junior Member
The coils are a different part number for the Gen2 3.5 Ecoboost Motors.
2017+ F-150 & Raptor 3.5 Ecoboost Coil P/N HL3Z-12029-A
2015-2016 F-150 3.5 Ecoboost Coil P/N BL3Z-12029-C
Old 10-26-2017, 05:41 PM   #9 (permalink)
PyroRaptor413's Avatar
Will the Genuine Ford Motorcraft OEM Iridium Spark Plugs SP-542 CYFS092YPT be compatible with 17-18 MY? When trying to order, it is saying not compatible.
PyroRaptor413 is offline   Reply With Quote
Old 10-26-2017, 06:52 PM   #10 (permalink)
Junior Member
Yes, it is compatible.
GEN 2 Engine misfire message Mason5905 Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 86 01-17-2018 01:45 PM
Cylinder 7 misfire SaleenSanders01 Ford Raptor Problems and Questions Forum 3 03-08-2017 06:13 PM
Misfire cylinder 1 detected cahek65 Ford Raptor Problems and Questions Forum 9 11-04-2016 07:15 AM
Startup Misfire jlauth Ford Raptor Problems and Questions Forum 41 09-24-2012 08:43 AM
Cylinder 8 misfire and more... whisler151 Ford Raptor Problems and Questions Forum 22 06-22-2011 10:56 AM
