k-rub
I installed the Full Race CAI a few weeks ago. Install is pretty simple. It's a plug and play system. You can do it all with a flathead screwdriver and a T25 torx drive. The torx drive is used to remove two small bolts on the top of the intake box cover. The cover then hinges open for easy access to the filters. The Full Race upper intake box connects to the factory lower box using the factory clips. You can disconnect the clips and access the filters from the bottom if you don't have the T25 torx.
Full Race's site has install instructions, but they are for an older Ecoboost. It's a an easy install though.
https://www.full-race.com/store/ecoboost/2017-f-150-and-raptor-ecoboost-dual-3-cold-air-intake/
I like this system because it separates the intake into two different 3" tubes. One intake for each turbo, instead of combining them like the factory intake. The filters are K&N filters.
I can hear more of a turbo sound. I personally don't really much care about that. Plus my exhaust sound is much louder.
Overall I'm happy with the setup.
