Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2]
Failed Tune Install - Truck Won't Start
This is a discussion on Failed Tune Install - Truck Won't Start within the Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
I was in the process of switching from one tune to another when something went wrong with the install. I ...
Like Tree14Likes
Old 09-24-2017, 01:14 AM   #1 (permalink)
Default Failed Tune Install - Truck Won't Start
I was in the process of switching from one tune to another when something went wrong with the install. I am getting an error message stating that I must install the stock tune, but when I try loading the tune on my nGuage that I believe is the stock tune, it won't install, nor will any other tune install. As it stands now, my truck won't start!!!! Any advice? I disconnecting the battery for ten minutes, but that did nothing. Please help!!!!
Jeff-Ohio is offline   Reply With Quote
Old 09-24-2017, 01:52 AM   #2 (permalink)
kandewinn's Avatar
Would like to know what tunes you were installing. If the install was interrupted, which it sounds like it was, I would think you're probably looking at a tow to the dealer for a computer reflash, cost...??? Please update with results/fixes
kandewinn is offline   Reply With Quote
Old 09-24-2017, 06:07 AM   #3 (permalink)
1BAD454SS's Avatar
Don't know about the latest generation trucks , but 10 - 14's if your battery voltage dropped during the tune install , you would potentially brick the PCM . You may have a weak battery? Or power drain, doors open or lights on. People used to put a small charger on battery during the flash to ensure voltage didn't drop. I only Change tunes when i'm home in my driveway for this reason.
Mcnawsty likes this.
2014 FX4 Tremor 420rwhp ,2010 Raptor 6.2L 2.9 Whipple 650 hp kit .2002 Lightning 3.4 whipple 800 RWHP, 1993 454 SS 502 ci and 2.4 kennebell, 1979 10th annivesary trans am 400 4spd ,2015 POLARIS Scrambler 1000,
1995 BANSHEE ,1985 Yamaha RZ500 4 cylinder 2stroke
1BAD454SS is offline   Reply With Quote
Old 09-24-2017, 07:42 AM   #4 (permalink)
NASSTY's Avatar
HP should be able to send you a (recovery) stock tune.
As luck would have it...this sort of thing usually happens on weekends when you may not be able to get a hold of customer support.
I usually load tunes at home with my battery tender hooked up as well.
I did do it once at the track with my old truck and prayed to Jesus the whole time.
NASSTY is offline   Reply With Quote
Old 09-24-2017, 09:18 AM   #5 (permalink)
Guy
Best advice I can give would be to call MPT. Also kick out an email to them. Hopefully there is s workaround for this problem.
Guy is offline   Reply With Quote
Old 09-24-2017, 10:27 AM   #6 (permalink)
Smokeshow60's Avatar
SgtMajor of the MemeCorps
Where in Ohio are you located
Smokeshow60 is offline   Reply With Quote
Old 09-24-2017, 11:18 AM   #7 (permalink)
Man sorry to hear, don't have any advice but after reading a thread like this, just scares the daylights out of me if in fact the pcm is bricked. Understand pay to play, but on a 70k truck that's a lot of payin' for playin'... Maybe conservative and go w/ jdm or scorcher. Even though it doesn't leave a footprint my understanding is in fact they can tell the perimeters were out of wack, but much harder to prove my guess would be. Anyway best of luck to you and hope you find a simple solution.
cobra281 is offline   Reply With Quote
Old 09-24-2017, 11:44 AM   #8 (permalink)
2014RubyRed's Avatar
OP must have just got drunk and worry about it Monday.......crickets
ZaneMasterX likes this.
2014RubyRed is offline   Reply With Quote
Old 09-24-2017, 11:55 AM   #9 (permalink)
shelteredraptor's Avatar
Maybe he took his truck out to the wilderness with a hot babe and decided to show her his "tune" and he wrote that post just as his battery went dead on his phone. Somewhere deep in Ohio, Jeff be wishin' he didn't do that.
shelteredraptor is offline   Reply With Quote
Old 09-24-2017, 11:57 AM   #10 (permalink)
MTF's Avatar
MTF
I would try a battery disconnect (the ground only) for a good 20 minutes and at the same time charge the battery.
Then after hooking the battery back up put the charger on trickle and keep the battery charging.
This is about the only thing you can try for now till MPT responds to you.
I'm I correct in assuming the IC fans run when the key is on?
Also make sure everything is off in the truck, and I mean everything!!!
Don't open doors, roll windows up or down.
Good luck
Whipple 700+ HP Upgrade Package, Oil and Fuel pump upgrades, Custom Deavers +2 Rear Springs, Axle Exchange Driveshaft, Rogue Racing Traction Bars, Hellwig rear sway bar, Pace Edward electric bed cover with remote, Pop & Lock Tail Gate lock, Mud Flaps, Window Rain Guards, EZ Down Tailgate, Bed Rug,
Future Installs: Brembo Brakes 15" Gran Turismo
MTF is offline   Reply With Quote
Tags
error, start, stock, tune
Push Start install ASars Ford Raptor Interior Modifications Forum [GEN 1] 33 12-23-2017 10:47 AM
Start up revs after tune... Danactive Ford SVT Raptor General Discussions [GEN 1] 3 02-24-2015 12:44 PM
Lost remote start after a Tune? englishrodder Ford Raptor Problems and Questions Forum 8 11-25-2014 07:05 PM
Whipple install then what about tune florchak Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 3 08-07-2014 06:06 PM
Corsa Exhaust cold start w/ tune video... swoop1156 Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 1 08-07-2011 05:03 PM
