Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2]
Engine ping or valve train noise???
This is a discussion on Engine ping or valve train noise??? within the Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
With about 1000 miles on my gen 2 and in sport mode while climbing through the gears I heard either ...
Old 08-13-2017, 02:09 PM   #1 (permalink)
Junior Member
Default Engine ping or valve train noise???
With about 1000 miles on my gen 2 and in sport mode while climbing through the gears I heard either engine ping or valve train noise....only heard it once and I haven't really tried to mimic it. After watching Barnetts videos I'm scared that I could have possible cam phaser issues in time as well.. the noise came about after slightly letting off throttle, so first I thought turbo boost actuator noise.. truck sounds fine on idle and has driven fine ever since..let me know if anyone has heard anything like it.
Bowewelding is offline   Reply With Quote
Old 08-13-2017, 06:14 PM   #2 (permalink)
Welcome to FRF. It could be nothing, it could be someone beside you with a bad catalytic converter, it could be something. Chances are, if you have either pinging or a mechanical issue it will be repeatable. If you suspect you can repeat it, Iíd get a go-pro and mount in the engine bay and take it for a spin. You want a cam with decent sound.
The actuators are kind of loud at start up but I donít hear them otherwise.
smurfslayer is online now   Reply With Quote
Old 08-14-2017, 11:26 AM   #3 (permalink)
Junior Member
Lmoa..when I first heard that noise I thought for sure the truck was going back to the dealer. But just as fast as it started it had stopped and nothing seems to have come of it.. I ruled out pinging because I had 91 octane in it and I had been driving it kinda hard with no other noises heard...my biggest concern is those cam phaseres and maybe I heard a little valve train collision..oil pressure seems good at the gauge. How did u guys "break in your engines?"
Old 08-14-2017, 01:52 PM   #4 (permalink)
Personally, I did my best to reenact the chase scene from Bullitt using the Raptor.
then, once the test drive was over, things got serious.
Old 08-14-2017, 03:32 PM   #5 (permalink)
SilverBolt's Avatar
Hired Gun
Ping will only happen while under throttle not when you let off. You can rule that out. The engine has to be under a load for pre-detonation (ping) to occur.
2012 Toyota FJ Cruiser
2018 Raptor Screw 802A White
SilverBolt is offline   Reply With Quote
Old 08-15-2017, 03:15 AM   #6 (permalink)
Junior Member
Thanks for the response..i ruled out ping noise aswell...and i think if I had any sort of cam phaser issue, or problem it would throw a light?? Do you guys run fully synthetic oil?? And how many miles?
Old 08-15-2017, 11:14 AM   #7 (permalink)
Banned
Cam phaser rattle (noise they make prior to failure) won't throw a CEL. When phasers fail, they stretch the timing chain. That event will trigger the CEL.
Mcnawsty is offline   Reply With Quote
Old 08-16-2017, 01:38 AM   #8 (permalink)
Junior Member
Going to pull the oil and fill with full syn motorcraft..what do u guys run?
Tags
cam, ecoboost, kraptor, phaser, turbo
6.2 intermittent valve train ticking noise at start up ?????????????? RV67 Ford Raptor Problems and Questions Forum 147 11-29-2017 03:16 PM
Preignition - engine ping UMKP Ford F-150 Raptor General Discussions [GEN 2] 1 08-03-2017 11:37 PM
Engine Ping on accelleration? anyone else? Renomaan Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 5 06-19-2017 11:27 AM
whirring humming noise '13 SCREW.Drive train? sidelock Ford SVT Raptor General Discussions [GEN 1] 5 02-21-2017 02:56 PM
TSB 10-25-7 6.2L Engine Tick Noise with Engine Misfire Codes BigJ Ford Raptor Recalls | TSB's | SSM's 10 05-16-2016 03:40 PM
