Engine Ping on accelleration? anyone else?
Renomaan
I took it relatively easy on the GEN2 thru the 1st oil cycle, now on 2nd oil change and driving with the foot more into it.
Disabled the Fake engine noise and I can hear (More than once) Detonation ping on heavy acceleration, usually while its shifting 1st thru 4th.
I'm running Sunoco 93. I suspect its always been there but masked by the fake engine noise thru the stereo
Anyone else hearing this?
onebadf150
New Orleans
Change fuel. that happens to me with shell.
I still have the ‘audio enhanced engine noise’, it’s not fake, it’s very real !
I’ve not heard any pinging though. You can only hear it with the engine audio disabled?
I’d have it to the dealer, you should not be pinging on 91+ octane fuel
The pinging - is it audibly discernible as engine knock? is it light, medium, heavy? only under heavy throttle gears 1-4?
normally I’d expect less of that than say 8-10 at 1-2k rpms when the truck tries to boost its way to faster speeds rather than downshift. You don’t hear any pinging under “lugging” conditions - low rpm, outside the power band and higher than usual load?
Your described symptoms sound like an ECU, possibly programming issue.
