boost gauge
wipit
Hi All,
My boost gauge doesn't read psi, it shows kpa see picture.
Is there a way to change that?
82jumper
North Carolina
Hi All,
Looks like everything is set to metric (note KM to empty, not Miles on fuel) I don't think there is a way to selectively show some units in imperial and some in metric.
wipit
wipit
Thats just great, what does the kpa stand for , and what is it reference to psi.
82jumper
North Carolina
Kilopascal is a metric pressure unit and equals to 1000 force of newton per square meter. The abbreviation is "kPa".
Psi is 1 pound of force per square inch.
Google will do conversion for you
JetDriver480
Not sure if this works but try in your Digital Speedometer being displayed hitting the 'OK' button will change it between KM and MPH. Curious if that changes all from Imperial to Metric... worth a shot.
wipit
wipit
Please explain a bit better,
waddellw
Mississippi
You can change all your guages over in settings by setting it to mph and so on. It should be under the settings menu on the driver's display
Dane
Littleton, CO
They're saying your truck is set to metric. kPa is a metric version of PSI. Like kilometers instead of miles. It's not just your boost gauge.
