AFE exhaust!!
NJSP117
New Jersey
Wassy
I like it. Best of what's available at the moment in my opinion.
crash457
I'm Batman
St. Louis, MO
Most catbacks on turbos aren't going to net any gain. If you don't remove the restriction at the downpipe, you won't really see any benefit other than sound.
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
And if you remove the cat you remove the warranty... I'm not confident in doing that quite yet.
crash457
I'm Batman
St. Louis, MO
You don't need to remove the cats. Most newer OEM cats flow just fine. The issue is the downpipe from the turbos to the cats. Exhaust can only flow as good as its weakest link. Putting a bigger exhaust on from the cats back won't offer any gains since the engine can not push the exhaust through the downpipes any faster. If you want to just change the sound (which is really all a cat back will do), you can change the muffler and get the same results.
Azholley
Peoria, Arizona
Makes sense... so do you think removing the down pipes would remove the warranty? I was planning on opening that up.
