Wierd Buzz Noise and Vibration
lightman02
New Jersey
Took my truck out last night and was with a friend, stopped at a light and we both noticed a weird vibration on and off noise that sounded like an electric motor running. The only thing I can compare the sound heard inside the truck is to a central AC unit fan ( Buzzz, Buzzz, Buzzzz) Didn't hear or feel it again until I got back to my driveway, got out of the truck with it running to check. It sounds like it's coming from the lower front, you can hear it but it's not overwhelming at all. Keep in mind the engine RPM's don't fluctuate and it doesn't seem like it's coming from the engine itself. The AC or any climate functions were not on all, so it's not related to that. I know I'm under warranty, just wondering if anyone had similar issues. Sounds like it's coming from lower the main radiator fans. We do have separate intercooler fans, correct?
I’ll bet it’s either the radiator or i/c fans.
April Raptor Assault truck number 9 had a rather loud, cyclical humming noise, troubleshot as the fans.
K1llD4shN1n3
Colorado
I was in truck 9 too and I remember that noise. Was pretty loud but seemed obvious it was the fans.
L
lightman02
New Jersey
Just an update on this, it was the intercooler fans. They are held in with rubber mounts between two plates, there is no bolts so whole thing kind of floats. When I cleaned my truck from off-roading the dirt must have gotten pushed through onto intercooler fins onto the fans, dried and threw the whole thing off balance. A nice direct cleaning to the fans with a garden hose got rid of the dirt and seems to have solved the issue. Good thing is that this can be done with the skid plate on.
RenegadeReady
Thanks. I was having the problem for about two months, I took my truck to the dealer and they couldn’t find what was wrong. I read your thread and sprayed my intercooler, once I did that the problem stopped.
RenegadeReady
Quick update. So spraying where the intercooler is located did help, and my raptor didn’t experience any vibration for about a week. My raptor had small episode this past weekend but since then the symptoms have been absent. I took my Raptor to Ford Monday the 12th 2018 but they were on able to find any issues with my truck for the second time being at the dealer for the same issue. According to them my truck is running fine... fusterating I guess you can’t take a off road truck off roading lol
