butts182
Sounds like a turbo seal
95 percent it's a turbo seal. Esp going through water with hot turbos, the instant change from hot to cold will cause issues. especially with new turbos where the metal hasn't shrunk and stretch for thousands of miles.
My old eco boost would smoke a little on start up, but it'd would go away after a bit. Noticed it on a friends when he starts up as well.
Other than that car had strong power and no hiccups the entire time I owned it and I didn't even have a weephole.
I doubt much water made it into your engine. Based on the hot glow from the front tire well, you probably warped some part of the turbo/Turbos and it destroyed the seal.
Agreed. I've taken my Rap through a river 4 ft deep an had no issues since. The intake sits high enough that it wouldn't draw water unless it was prolonged exposure.
Or forced in due to high speed. Looking at his airbox the water had to be moving very fast to fold up the air filter.
My guess. The air filter collapsed covering the opening which prevented the water from immediately enter the turbos/engine. Once the filter shifted whatever water/mud left in the airbox found it's way down stream.
