Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Wheel Spacers
This is a discussion on Wheel Spacers within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by CUSTOMWHEELS4U The stock offset will give you the least amount of issue with 37's. Pushing them out ...
Like Tree5Likes
Old 08-02-2017, 04:35 PM   #11 (permalink)
Originally Posted by CUSTOMWHEELS4U View Post
The stock offset will give you the least amount of issue with 37's. Pushing them out 2" would put the wheels 3/4" past where a Method wheel would sit making 37's pretty difficult to fit. Anything is possible. Just depends on how sharp you want to turn or how much you want to cut.
Since putting 37 inch tires on seems to be an issue, I was planning on using wheel spacers with 35 inch tires, not 37 inch.
Jeff-Ohio is offline   Reply With Quote
Old 08-02-2017, 04:40 PM   #12 (permalink)
CUSTOMWHEELS4U's Avatar
I would try to go with a 1.5". Call Lenny over at Motorsport Tech and see if 1.5" will work or if the studs are too long. I'm only saying 1.5" cause 2" is quite a bit and you may run into slight issues even with a 35". He gets pretty busy over there so just a pre-warning you might be on hold for a while. 775-351-1000
CUSTOMWHEELS4U is online now   Reply With Quote
Old 08-02-2017, 05:28 PM   #13 (permalink)
I broke down and gave him a call and ordered 1.5 inch BORA wheel spacers. I will post pics and give a review when I get them installed. I will be running these with my stock tires and rims.
Old 08-02-2017, 05:47 PM   #14 (permalink)
Nice!! He makes really high quality spacers and adapters. I think the 1.5" was the way to go.
Old 08-02-2017, 07:37 PM   #15 (permalink)
JetDriver480's Avatar
I am VERY VERY VERY happy with my +1mm offset wheel. Gives me about 1.5" of tire outside of the wheel well.
2017 Black Raptor Super-Crew 802A
DORA 2/6/17, VIN Issued 2/14/17, Build Date 3/12/17, Delivered 4/10/17.
THESE RED LETTERS HELP ME FIND MY POST
JetDriver480 is offline   Reply With Quote
Old 08-02-2017, 10:01 PM   #16 (permalink)
NASSTY's Avatar
My wheels stick out 1.1" more than the stock wheels. I wouldn't want them to stick out any further. My paint will probably take a beating this winter.
JetDriver480 likes this.
NASSTY is offline   Reply With Quote
Old 08-02-2017, 10:17 PM   #17 (permalink)
WhatExit?'s Avatar
I would love to put 37 inch tires on the truck, but since that doesn't seem like it's an easy thing to do without issues, I was thinking about changing the stance with some wheel spacers instead of the larger tires. I won't be doing any hard-core off-roodng because I have other off-road vehicles, so probably just street use and some gravel roads for now.
Aren't you the guy complaining about vibration? Just wondering...
WhatExit? is offline   Reply With Quote
Old 08-02-2017, 10:23 PM   #18 (permalink)
Just vibration in the gas pedal which I think is caused by an issue with the torque converter, but the dealership says it is an issue with harmonic vibration from the exhaust. Everything else is rock solid.
Old 08-07-2017, 03:41 PM   #19 (permalink)
June158's Avatar
Junior Member
Anyone know what the backspace is on the stock cast wheels is?
TIA
June158 is offline   Reply With Quote
Old 08-07-2017, 03:48 PM   #20 (permalink)
TIA
Roughly 6", 6" and 2mm to be exact
Tags
rims, spacers, tires, wheels
Wheel Spacers/adapters? chi_weezy Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] 4 05-17-2017 02:10 PM
2" wheel spacers Therealdougkelly Want to Buy 3 06-15-2016 02:59 AM
Wheel Spacers, are you with or against? TamerSaad Ford Raptor Wheels & Tires Forum [GEN 1] 40 05-31-2014 11:54 PM
Wheel spacers? whtrapta Ford Raptor Wheels & Tires Forum [GEN 1] 13 11-24-2012 07:27 PM
Wheel spacers...really? Talon Ford SVT Raptor General Discussions [GEN 1] 8 10-21-2010 08:55 PM
