Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I hear it occasionally. Truck is off and sitting and it will make a buzzing noise. Does it after you shut the doors as well. Anyone know? i asked once before, but cant find the post.
It's the wastegate solenoid. Perfectly normal as long as it isn't too loud and doesn't last more than 30 seconds. You can duplicate it very easily. It will do it after power accessory power is cycles off. If you open the door, the parking lights come on and accessory power is activated. When they shut off you will hear it.
I's triggered by a power off event. Once the BCM shuts off the accessory power, it triggers the wastegate solenoid. When you open the door, the parking lights go on, After you shut the door, the parking lights go off after 30 seconds (or whatever time you have set in the vehicle settings). This triggers the power off event.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
