Shooter10x,
The wires are in the right footwell. You pull the panel access back like a door (swings out from the carpet side). In my truck (finally arrived!) they were in the far lower right of the area behind the panel door, wrapped to the large bundle of wires. Depending how they are wrapped they may be hard to see, and in my case they were a real b*t h to fish out since there's not much room for your hands in there, and you don't want to be randomly yanking on stuff. And the wires aren't long. Best advice I can give you is to use a flashlight and try to match up the wire colors with the manual supplement so you're positive the wires you're trying to pull from the wire bundle are the right ones. The wires will also have their ends capped in insulating black plastic.
Hope that helps.
