Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Upfitter switches not working
This is a discussion on Upfitter switches not working within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
I have a 2017 Raptor and went to hook up some lights. I had no power to the left bunch ...
Old 09-11-2017, 09:17 PM   #1 (permalink)
Junior Member
Default Upfitter switches not working
I have a 2017 Raptor and went to hook up some lights. I had no power to the left bunch of wires under the hood. Also, none of the upfitter lights light up, the words AUX 1, Aux 2, ect., on the overhead console. I hooked up a power meter to each of the 6 wires under the hood and all were dead. The lights would work if I hooked up directly to batter, but not to wire. Shouldn't the individual AUX lights have light up on the overhead console light up? Seems like something was not installed correctly. Do I have to do something to make them hot?
HUSKERHOSS is offline   Reply With Quote
Old 09-11-2017, 10:19 PM   #2 (permalink)
Make sure ignition is on. There are 2 sets wires ( 2 bundles, 12 wires). One set are hot, one set just goes back through the firewall (so you can hook then up to hot and run something from inside).
Hope I just saved you some stress, phones calls, bad words, etc....ask me how I know.
Piranharaptor is offline   Reply With Quote
Old 09-11-2017, 10:23 PM   #3 (permalink)
Junior Member
Thank you for your response. Yes, using the correct bundle and ignition is on. That is my problem, neither set is hot, understand only ones on left that go to aux. switches are supposed to be. Something has to be wrong as every one of the 6 switches on console does not light up.
Old 09-12-2017, 11:11 AM   #4 (permalink)
Aaron's Avatar
Meme Corps Commandant
I'm assuming you've checked your fuses for your aux switches? If not, do that.
COMMANDANT OF THE MEME CORPS
MCLTW!
It is not who we are that matters....what matters is our memes...
Aaron is offline   Reply With Quote
Old 09-12-2017, 11:47 AM   #5 (permalink)
vooo11's Avatar
Junior Member
if not drop it off at the dealer/ they will solve it under warranty
vooo11 is offline   Reply With Quote
Old 09-12-2017, 01:16 PM   #6 (permalink)
Junior Member
Fuses are there. Two weeks wait until they could get me in.
GEN 1 2011 SCREW window switches stop working, then start working after power off Blu808 Ford Raptor Problems and Questions Forum 5 01-19-2017 06:31 PM
upfitter switches adammartin13 Ford Raptor Problems and Questions Forum 3 07-18-2016 06:49 PM
Upfitter Switches Iron Creek Ford Raptor Audio/Video/Electronics Forum [GEN 1] 15 09-15-2014 05:52 PM
Upfitter Switches JayneCobb Ford Raptor Audio/Video/Electronics Forum [GEN 1] 3 05-27-2014 01:34 AM
