Upfitter Switch Tailgate Release
Spartan1
Mars
So if I am driving down a back road and hit all of my up switches at then same time to turn on my lights will my beer cooler fall out of the back of my truck if I do this?
WhatExit?
48th state
Guess it depends on where your beer cooler is :ROFLJest:
---------- Post added at 08:31 PM ---------- Previous post was at 08:28 PM ----------
Today I finally became sick of not having a way to "pop" the tailgate from inside the truck besides digging in my pockets for the key fob. So, I started tinkering around until I found a way to pop the tailgate using the up fitter switches. Here is a short video and writeup I made to cover it if anyone else is interested. Costs less than $10 and takes about 30 mins. 2017+ 802A trucks only.
shelteredraptor
on a rock
If you're driving down a back road with your beer in the bed, you totally ******* deserve to lose it.
But noooo, the truck active release system won't let the tailgate open.
Ruby
Ruby
Fort Bragg, NC
It doesn’t activate while driving. It uses the same system as the fusion and focus use for their trunk releases. It’s doesn’t do anything once you start moving. Your beer is safe!
---------- Post added at 01:35 AM ---------- Previous post was at 01:34 AM ----------
And no, the truck active release system won't let the tailgate open.
What he said^^
Spartan1
Mars
OK so switch number 6 it is. I am jealous of "what exits" setup in his bed. I could tie in more than just 1 beer cooler.
Ruby
Ruby
Fort Bragg, NC
Ruby...what do you have that ARB fuse hooked up to?
I have the ARB CKMTA12 Dual compressor mounted under the passenger side rear seat.
wheelman55
Big Bend or MN
Cool. I travel with a Viair 440P and a Safety Seal plug kit.
Did you plumb the air to the wheels? Also how did you route your wires? Assume you used 8 awg?
I'm awaiting my 18 and want to install a second battery. Any idea wear I can fit the second battery?
Thanks.
Ruby
Ruby
Fort Bragg, NC
Thanks.
I didn't plumb air to the wheels. I have a air chuck on the compressor mount itself, and one on the rear bumper that mirrors the keyhole for the spare tire hole.
Since the ARB compressor is a Dual pump compressor, each pump has its own wire and fuse. Each pump is ran using 10AWG wire. I routed the dual 10AWG wires through the firewall behind the glovebox area, then under the kickplates and door sills all the way to the area behind the seat. From there I routed along the power amp wires to make it look seamless. I grounded the compressors using dual 10AWG as well.
Attacted is a picture of the setup before I ran an addition airline out to the rear bumper.
93,171
56,440
jumpcutter
