it's a known issue... dang, popping up quite a bit lately!
SSM 46139 - 2015/2016 -F-150 - Intermittent Loss Of Throttle Response - Multiple Warning Indicators And/Or Multiple Diagnostic Trouble Codes (DTCs)
Some 2015-2016 F-150 vehicles may experience intermittent loss of throttle pedal response, illuminated wrench, hill descent, airbag, anti-lock brake system (ABS) and/or advanced trac warning indicators and/or P2122, P2123, P2124, P2125, P2127, P2128 and/or P2138 DTCs. This may be caused by the Accelerator Pedal Position (APP) Sensor 14A005 harness being improperly routed behind the brake booster to brake pedal bracket. If the harness is improperly routed, loosen the bracket to free the harness. Inspect and repair damaged circuits before properly routing the harness. If the harness is properly routed, proceed with normal diagnostics in the Workshop Manual (WSM).
SSM 46667 - 2015-2017 F-150- Intermittent Lack Of Steering Assist - Multiple Illuminated Warning Indicator Lamps
Some 2015-2017 F-150 vehicles may exhibit multiple illuminated warning indicators and an intermittent lack of steering assist. Prior to performing any diagnosis or repair, visually inspect the 3C221 wire harness near the air compressor pulley for possible damage.
SSM 45421 - 2015 F-150 - MS-CAN Network Concerns - Built On/Or Before 6/26/2015
Some 2015 F-150 vehicles equipped with Multi-Contoured seats may exhibit various intermittent MS-CAN network related symptoms such as Blind Spot Indicator System (BLIS), Cross Traffic Alert (CTA), Rear Park Assist (RPA) warning indicators being illuminated and/or intermittent operation of the A/C and/or Power Running Boards (PRB). Inspect the Multi-Contoured Seat Module (SCMG) wiring harness for chafes or shorts due to contact with the drivers and/or passenger seat backrest frame. Repair or replace the wiring harness as needed, following normal Wiring and Workshop Manual procedures. If needed, the wiring harness retainer clips can be relocated on the seat frame to prevent excessive wiring harness movement and chafing.
