Towing - first trip thoughts...
rmarquette
I pulled 14' enclosed trailer from WI to FL and back and averaged over 10MPG. 36a7f8d89d8ecb2cd00917ea94df608a.jpg
DarinT
I tow a little, but I find it important to balance the trailer tongue weight or you can feel more sway, even with the WDH.
T
tmaxxer
To the OP:
Where you using Tow mode?
What gear and rpm where running?
Sometimes manually dropping a gear will let the eng run easier and might get a little better mileage...
Yes, all in tow mode. Didn't check rpms or gears.
MPG was actually 8.6 avg after checking the truck computer. I am pleased with how it ran. Didn't get the Raptor to haul all over. Except haul butt in the desert. :biggrin:
---------- Post added at 01:14 AM ---------- Previous post was at 01:11 AM ----------
Altitude, weather, and terrain very likely could be causing the disparity in MPGs. OP should post where he towed, which route, etc. to have an accurate comparison.
I didn't get my Rappy to tow, other than maybe my flat bed with my RZR or maybe the Scout from time to time. That's why I have the Super Duty.
Towed from Vegas to Southern Utah up the I-15 and back and around the 2 lane roads there. There are climbs and flat parts to the highways.
bwep
Mass
DANACO
xxaarraa
Southlake, TX
To the OP:
Say more about dropping a gear. Why would making the engine rev higher be better for mpg?
tmd11111
To the OP:
Towing mode doesn't improve MPG's, neither does dropping a gear manually.
