Tire/Wheels for Stock Raptor
JetDriver480
First Post... Just ordered a Raptor and looking for advice. Looking to put Mud Terrains (likely Toyo M/T) and the best combo. Looking for the wheels to stick out to the wells an inch maybe to give it a better stance. Thinking 35's....
Anyone have advice on this?
crash457
I'm Batman
St. Louis, MO
Stock tires are 315/70r17, which is essentially the same size as 35x12.50-17 already. Stock offset is +34. Subtract 25.4 for every inch you want to move them out. If you want to move them out an inch, look for an offset between 0 and +10.
John813
PSL/Jupiter
FWIW I have a set of 6x135 14x1.5 Black Splined Lug Nuts from SDHQ that are new.
Willing to let them go for $60 shipped.
Popular choices for the trucks probably will be between Methods, Fuels and possibly Icons.
Each of those will give you that look.
JetDriver480
JetDriver480
Anyone know if my 2007 Ford F150 has the same bolt pattern as the Raptor? Would love if I could put my 07's Fuel Wheels onto my Raptor.
jsstalli
Wheels
I have the Fuel Hostage in 20x9 with a +1 offset. They stick the tire out just outside the fender but no so much that it looks ridiculous. The lug nuts are different than the gen1. New lug nuts are 14x1.5, old ones were 14x2.
jsstalli
Wheels
Here's my setup...
NO LIMIT
Alberta
Your pics look really good for the offset...so your rims are 20x9 with a +1mm offset correct? I was looking at +18mm offset but now I'm thinking closer to a +0
jsstalli
IMO as close to 0 offset is the way to go.
NJSP117
New Jersey
Are the lugs for aftermarket wheels? Or for stock wheels?
JetDriver480
JetDriver480
Truck looks sharp! Any rubbing? I am thinking about 18x9 Fuel Wheels with a +1 offset spinning Toyo 33x12.50 R18 Mud Terrains...
I am new to the Raptor and wasn't sure if wheels that stick out of the fender would be an issue during heavy off-roading (not planning on doing much of that as it's a daily driver) with the suspension on the Raptor.
