Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Tire Rotation
This is a discussion on Tire Rotation within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by CUSTOMWHEELS4U I'm pretty sure the raptor's ecu can only see 4 sensors at a time so a ...
Like Tree4Likes
Old 08-25-2017, 12:16 PM   #11 (permalink)
crash457's Avatar
I'm Batman
Originally Posted by CUSTOMWHEELS4U View Post
I'm pretty sure the raptor's ecu can only see 4 sensors at a time so a 5th sensor and a relearn every rotation would be fine. Although I don't think the Raptor displays which tires are where so you shouldn't have to re-learn every rotation unless a 5th sensor is added.
Not sure about Gen1 but the Gen2 shows the TMPS by location (FR,FL,RR,RL) So you need to relearn them after each rotation. This can be done without the tool. Use the same process as below.
1) Make sure your tires are inflated to the recommended psi.
2) Turn ignition to the on position. If you have a push button start, push the start button without pressing the brake pedal.
3) Push the hazard light button 6 times. The horn should honk and you should see "Train left front tire" in the LCD display between the tach and speedo.
4) Release air pressure in the front left tire until you hear the horn honk. The LCD display should now read "Train right front tire".
5) Release air pressure in the right front tire until you hear the horn honk.
6) Repeat for the right rear tire, and then the left rear tire.
7) You should now see "Training Complete" in the LCD display.
8) Fill your tires back up to the recommended pressure
I stole this from here:
How To Train TPMS with no learning tool
If you use the tool it just means that you don't have to deflate and re-inflate the tires.
WhatExit? likes this.
2017 Ruby Red SCREW 802A-Ordered 8/3, Built 10/14, Released from Factory 12/12, Accepted by Shipping Company 12/27, Delivered 1/19
crash457 is offline   Reply With Quote
Old 08-25-2017, 12:40 PM   #12 (permalink)
CUSTOMWHEELS4U's Avatar
GEN 1 did not. I have only really checked out an 801A package. It didn't look like it had locations for the tires but I didn't play around with it too much. It's nice Ford finally did this. GM has been doing it for over a decade. That was the only one up they had on ford lol.
CUSTOMWHEELS4U is offline   Reply With Quote
Old 11-28-2017, 04:37 PM   #13 (permalink)
WhatExit?'s Avatar
I want to rotate the tires including the spare since I paid for it.
I assume I can add a TPMS for the spare and have the Raptor re-learn the 4 tires on the ground ignoring the spare.
Here's a TPMS for a Ford F-150 2017 from CJ Pony Parts
https://www.cjponyparts.com/ford-tir...017/p/TBANDS8/
$39.99 but may not be in stock - good price to have when talking to Ford dealer
2017 Magnetic SuperCrew Cab 802a; Raptor Tech Pkg w/Adaptive Cruise; 17" Forged Aluminum (Beadlock) Wheels; 2nd Row Heated Seats; Moonroof; Tailgate Step; Exterior & Hood Graphics Pkgs (both removed); Carbon Fiber Pkg; Engine Block Heater. Added: new V1; BlendMount; XPEL Ultimate & Stealth Film; Tinted Front Windows; BedRug, Roll-N-Lock A-Series bed cover
WhatExit? is offline   Reply With Quote
Old 11-30-2017, 09:26 PM   #14 (permalink)
WhatExit?'s Avatar
I took my Raptor in for its first oil & filter change at the dealership today. I bought a TPMS and had them install it in my spare and then had them do a 5-tire rotation. Got the new (spare) on the front per the 5-tire rotation shown below.
They then reset the TPMS so the 4 tires on the ground are registered and reporting PSI to the Raptor's display. Next time I go there I'll have them do the rotation so I'm using the spare and getting value from it sharing the wear with the other tires.
Recommendation: Go to CJ Pony Parts or somewhere else to get a TPMS at a good price. I was able to get the stealership to reduce the price a bit but I paid more than CJ Pony Parts charges. Bring the TPMS to your dealership/tire store when they do the 5-tire rotation.
Old 11-30-2017, 09:32 PM   #15 (permalink)
Did they charge you extra or give you any guff about the 5x rotation instead of 4x?
smurfslayer is online now   Reply With Quote
Old 11-30-2017, 09:43 PM   #16 (permalink)
Seems like a lot of extra hassle to include the spare in rotation.
You do realize that you will be buying 5 new tires instead of 4 when you need to replace.
So any cost savings is minuscule at best
df4801 is offline   Reply With Quote
Old 12-06-2017, 12:05 PM   #17 (permalink)
I went with six tires. Bought another matching beadlock rim and tire. Discount tire did the work. I think that I paid $39.95 each for the two TPMS units. I'm doing a simple fronts to back, spares to front, backs to spares rotation.
I also had the wheel weights removed and put in balance beads. The beads are working great. 2,500 miles of pavement and 500 miles of off-road so far. Maxed the speedo out at 108 mph and it road smooth as silk.
I recommend both Discount Tire and the balance beads.
2018 Magnetic Screw, 802A, Technology pkg, Beadlocks, Moonroof, Heated Rear Seats, Tailgate Step
wheelman55 is offline   Reply With Quote
Old 12-09-2017, 07:41 PM   #18 (permalink)
I have beads in my Harley tires, but I heard there is a concern with using them in wider tires. I will never do anything but beads in a motorcycle based on my experience. Now you have me thinking about the truck tires.
costnsg is offline   Reply With Quote
TPMS and tire rotation questions OrangeAddict Ford Raptor Wheels & Tires Forum [GEN 1] 14 11-26-2014 12:26 PM
Tire problem after rotation OrangeTiger Ford Raptor Maintenance Forum 13 08-16-2014 04:51 PM
Tire rotation mfrunlimited Ford Raptor Maintenance Forum 18 10-29-2013 12:07 PM
Time for regular maintenance? Oil change/Tire rotation/Multi-point Inspect... Ask for "The Works" BigJ Ford Raptor Maintenance Forum 9 07-26-2010 03:57 AM
What's Ford Charging You for a LOF and Tire Rotation? BigJ Ford Raptor Maintenance Forum 18 04-14-2010 06:57 PM
