Swapping to OEM Beadlocks - TPMS Question
oswiff
Buying a set of the OEM beadlock wheels and tire and the seller is leaving the TPMS with the wheels.
When I get the wheels swapped out, will the TPMS work automatically or will I need them to be reset?
brettmess24
Not sure that is correct... you need to teach the truck where each sensor is - it's in the manual and not hard.
On my 18 I didn’t have to do a thing and the position was correct. YMMV
If You need to toggle to tpms and let air out of the tires starting with driver front and the horn will tell you it’s set up.
O
oswiff
So either way - it sounds like it's not difficult.
Thanks
bfr
Mountain West
Drive over 20mph for more than 2 minutes and you should be all set. If not the reset and retraining methods are in the manual starting around page 398.
