Test drive before you buy. A real test drive, not some guided, namby-pamby, tooling around city streets. Go BIG. If you ride, bring your helmet
Make sure sales-bot is prepared for you to conduct a proper test drive for a 70k truck.
Get pics. Lots of pics. All the way around, underneath, get the roof, interior, everything. Leave nothing to chance. If you spot a defect, point it out before you sign. Check under the truck for any hint of a leak, bent, or broken part. make sure you do a drive that includes some time with the radio off, windows down if tolerable. listen for issues. Test WFO throttle, hard on the brakes, drive modes, etc. Make sure all of it works before you sign.
Read up on here and you’ll find a bunch of users got hit with stuff that would have been caught in a very thorough “pre-flight” and test drive. If manufacturing goofed something up, this is the time to find it.
check your tire pressures right away first off. If they’re over 40 pounds, someone’s not doing their job. manual calls for 38, but some dealers just stuff them to max psi - these dealer mechanics don’t care. you will need to care for them.
if the tire pressures are that high, pop the hood and check the fluids - because they didn’t. Get your pics, video if you need to, and commence your test drive.
check again when you get back, make sure the hoses are still tight, nothing is leaking, hanging down or smoking. Features and inside stuff is secondary, and some of it can be covered in the test drive, but don’t ignore this. Some owners have had radio issues / sync stuff early on.
If you get any static, ask the salesman/woman to demo how to change the tire.
Seriously, my saleswoman was like “Yeah, I have all the time you need for a test drive.” not a hint of resistance or anything from her, s/m or owner.
Take it seriously, as you’re dropping a lot of coin here and it will be a big monthly nut. sign nothing until you have agreement on any discrepancies or deficiencies you identify.
look up the “post all your 2017 Raptor problems here” thread for some guidance.
Good luck, and post pics, or you will be branded a closet prius owner.
Oh... and Welcome to FRF!
