Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Rim change
This is a discussion on Rim change within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
New to forum. I was thinking about a wheel upgrade to Sota AWOL Anthra-Kote. They are beautiful rims. Smallest they ...
Old 03-18-2017, 08:07 PM   #1 (permalink)
Junior Member
Default Rim change
New to forum. I was thinking about a wheel upgrade to Sota AWOL Anthra-Kote. They are beautiful rims. Smallest they make is 20x9 same hub bore 87 and bolt pattern. I think I would need to go with 35 inch tires. My question is does anyone know if there would have to be any modification to the suspension for these wheels to fit, or could I just swap and go?
MAJ01 is offline   Reply With Quote
Old 03-18-2017, 08:09 PM   #2 (permalink)
Welcome to frf
TornadoRaptor is offline   Reply With Quote
Old 03-18-2017, 10:24 PM   #3 (permalink)
Bullishone's Avatar
You should get the RPG 1.5" collar to avoid any minor rubbing ...
Bullishone is offline   Reply With Quote
Old 03-18-2017, 10:34 PM   #4 (permalink)
Kowboy17's Avatar
make sure you check the lug nuts and if the stockers will fit into your aftermarket wheels. I just went through this today. Ford changed the thread on the 17's. 14 x 1.5. Most likely you'll need the thin lug nuts since the stockers have a big flair on the end.
Kowboy17 is offline   Reply With Quote
Tags
rims, tires, wheels
My first Oil Change. TheGreatDew Ford Raptor Maintenance Forum 7 07-05-2014 01:29 PM
First Oil Change on my '14 R1jamn Ford Raptor Maintenance Forum 27 06-16-2014 07:32 AM
DIY Oil Change? Stingray23 Ford Raptor Maintenance Forum 47 02-15-2014 04:52 PM
MPG change with 37's jeeper Ford SVT Raptor General Discussions [GEN 1] 35 01-16-2013 03:30 PM
LED Change-over Saber22 Ford Raptor Lighting Modifications Forum [GEN 1] 2 01-05-2013 11:27 AM
