Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Retrax and Aux switch
This is a discussion on Retrax and Aux switch within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Hi all, Is there a way to operate the Retrax power covers with the Aux Switches inside the truck? I've ...
Old 07-13-2018, 06:45 PM   #1 (permalink)
Junior Member
Default Retrax and Aux switch
Hi all,
Is there a way to operate the Retrax power covers with the Aux Switches inside the truck? I've been looking everywhere and can't find the answers I need. I found a wiring solution for some antennas (which was great), but still not enough info regarding these covers.
Is there another brand of power cover that is friendly to be wired to the aux switches?
Thanks!
CostaRicaRaptor is offline   Reply With Quote
Old 07-13-2018, 10:11 PM   #2 (permalink)
Default switches
switches will control anything you wish, u need the amp draw from retrax motor. Some swithes are up to 20 amp max. Any more than that and put a relay in to carry the load. Any reputible shop should be to wire.
cain072567 is offline   Reply With Quote
Old 07-17-2018, 11:01 AM   #3 (permalink)
Probably not.
You can definitely use the aux switches to switch the power supply to the retrax, but you would still need to open/close the cover using the fob that comes with it... unless you want to replace the electronics inside the cover, which would require some pretty serious electronics skills, and would certainly void the warranty.
Lasercat is offline   Reply With Quote
Old 07-17-2018, 11:34 AM   #4 (permalink)
trophycummins's Avatar
We have controlled them from the Fob. You dont need to replace the electronics in the cover.
It wasnt easy. If I recall we tapped into the module that receives the signal from the fob and triggers the cover to open and close.
Tim @ Galpin Auto Sports - Los Angeles, CA
95 Ford Bronco w/ Solo motorsports long travel and cage in progress.
2017 F150 With Mid Travel and King 3.0 coilovers/bypasses. SVC Bypass rack/King bumps/Deavers/shackles.
trophycummins is offline   Reply With Quote
Upfitter switch in parallel to backup light switch? Jetskimobile1 Ford Raptor Lighting Modifications Forum [GEN 1] 4 06-29-2016 05:14 PM
Retrax one? Txfight00 Ford Raptor Exterior Modifications Forum [GEN 1] 26 05-09-2013 02:59 PM
Headlight switch with fog light switch Shortbusdriver Ford Raptor Lighting Modifications Forum [GEN 1] 1 04-14-2013 01:16 PM
upfitter switch to toggle switch stsmith03 Ford Raptor Audio/Video/Electronics Forum [GEN 1] 0 05-16-2012 11:51 AM
My new retrax pro TRAPTOR Ford Raptor Exterior Modifications Forum [GEN 1] 8 03-07-2012 11:07 AM
