Raxiom Vent Guage
hmgt3
Anyone install the Raxiom vent guage?? How did you get the AC vent out?? Anything in the install I should be extra careful about?
Thanks in advance.
Sent from my G8142 using Tapatalk
Ownby
Huntington Beach, CA
I have the Raxiom multi gauge installed. Vent took a little force to pop off but I did not damage any clips or anything.
I found this forum that shows where all the clips are on the vent. I just used a plastic trim removal tool and pryed the top of the vent off the clips first then was able to pull it straight off by hand. Be careful not to pull too fast since there is an electrical connector behind the bottom of the vent for the spot lights.
https://www.f150forum.com/f118/interior-trim-pieces-removal-331970/
Good luck. The Raxiom gauge is awesome. Has a very nice and clean look.
hmgt3
hmgt3
Wonderful. That's exactly what I wanted to know.
Thanks
RGVRaptor
South Texas
I was looking at getting the P3 vent gauge, what's difference between P3 and Raxiom? They look almost identical.
hmgt3
hmgt3
Attempt to remove the AC vent was an epic fail. Tried pulling on, did not budge. Tried with trim removal tools couldn't get it off.
Any help is appreciated!!
BurnOut
I haven't been able to locate a complete list of parameters that this thing can monitor/display... does anyone know if such a thing exists? I am interested in EGT (which was mentioned in the video), but also oil temp (which I think would be more useful for me day-to-day).
WhatExit?
48th state
Not being familiar with the product I checked it out:
Features, Video & Details
Ideal for any Supercharged or Turbocharged F-150s
Real-Time Boost and Vacuum Monitoring
45 PSI Sensor Included
Battery Voltage Check
Integrated Digital Vent Gauge
Reuses Existing Left Hand OEM Vent Housing
Mounts in Factory HVAC Vent - Does Not Obstruct Airflow
Requires a Boost Tap for Installation
2 Year Full Warranty
Fits all 2015-2017 F-150s
