Rattling at Start Up
hugepops77
I am fairly certain there was a thread on here regarding a slight rattle - when the Truck is started. I can't find the the thread - is that rattle normal. It amost sounds as if a plate is rattling. It goes away after 30-60 seconds.. what is it? Any feedback is much appreciated!
mmaterni
Toledo Ohio
Check the exhaust heat shield on the exhaust pipe next to the crossmember. Sometimes the weld breaks.
Famous last words, "if you hit it faster it will smooth out some!"
H
hugepops77
Gen 2
---------- Post added at 04:08 PM ---------- Previous post was at 04:07 PM ----------
Yes; that is the the noise! Thrashing - Rattling at Start up! Thank you - that was the thread I was looking for!!
---------- Post added at 04:11 PM ---------- Previous post was at 04:08 PM ----------
What is the difference between this and the wastegate rattle?!
---------- Post added at 04:25 PM ---------- Previous post was at 04:11 PM ----------
I found the thread - was there ever a solution confirmed by members? Does Ford find this normal? See below:
http://www.fordraptorforum.com/f261/wastegate-actuator-rattle-54155/
