Payload
acg90
Virginia
What was the payload on the Gen-1? A couple of big guys in the cab and you can't carry much cargo.
Just did a google search and it looks like 970 for the Scab and 1170 for the Screw
ZaneMasterX
Mountains
The GVWR on that truck was 7050lbs, which is what the old scabs were. So it weighs 5922lbs. Interestingly enough when you run that vin from that truck on Ford ETIS it shows it as being a scab, but that truck is a screw. Granted its pre-production but still.
So the plot thickens...Nothing is clear cut with these damn things so far.
Chris's FX4
Chicagoland
Don't listen to me. Ran another Vin for a a 16 screw on Ford ETIS and it shows that as being called a double cab (3/4 door) as well which I thought meant scab.
Those yellow stickers will vary from truck to truck though depending on your option packages. I'm sure the panoramic roof doesn't help.
2014RubyRed's payload sticker on his 2014 screw is 1035lbs.
Any weight savings the Raptor has just went into other components.
acg90
Virginia
Here's a 2012 Screw which appears to be fully loaded.
