Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
My First Truck, 2017 Ford Raptor Supercrew
This is a discussion on My First Truck, 2017 Ford Raptor Supercrew within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by carholic Can you elaborate how one can do the FORSCAN? Did you do it yourself? Did a ...
Like Tree28Likes
Old 09-20-2017, 03:25 PM   #11 (permalink)
Default Forscan
Originally Posted by carholic View Post
Can you elaborate how one can do the FORSCAN? Did you do it yourself? Did a shop do it for you? I am in Southern Cal too.
Thanks.
Hi, I learned about Forscan on this forum. if you search, there are a couple of threads that will walk you through the entire process. I purchased an USB OBD interface from amazon for $30 bucks and ran the Forscan PC software on my PC.
Forscan thread
Forscan changes - tweak your truck
USB Device
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Bluetooth Device
---------- Post added at 12:25 PM ---------- Previous post was at 12:21 PM ----------
Originally Posted by CFIT View Post
How much of the upol is needed to do four wheel wells? Was there any left over?
I used about three liters (three bottles), but with this being my first application of the product, I wasted a fair amount on test surfaces like plywood and cardboard. I also applied three heavy coats, so two liters certainly could be adequate.
image98 is offline   Reply With Quote
Old 09-21-2017, 01:35 AM   #12 (permalink)
Thanks. Don't own a PC. I wonder if there is anyone that will do it for a charge. Better than me going out buying a PC.
carholic is offline   Reply With Quote
Old 09-21-2017, 09:12 AM   #13 (permalink)
Raven13's Avatar
Howdy and congrats
Raven13 is offline   Reply With Quote
Old 09-21-2017, 01:12 PM   #14 (permalink)
Default Forscan for PC
If you have a Mac, you can also run Forscan with Windows via BootCamp.
Old 09-21-2017, 07:07 PM   #15 (permalink)
Default Rear Sway Bar Performance
Originally Posted by xBryanHoodsx
Hey
Saw you put on the helwig sway bar is that the same part as for the regular f150 and how much of a difference does it make for the street handling of the truck.
Thanks
Bryan
Hi, I contacted Hellwig directly and they gave me that part number for the Raptor. Yes, it's the same kit for the standard F-150. The end links are adjustable. The U-Bolts are not 100 percent centered, but otherwise everything bolted in seamlessly. Street cornering and handling has improved tremendously. Prior to the install, I could feel the bed tilting through corners, but now its perfectly level and the trucks feels more balanced. I really wish Ford had included a rear sway bar as stock equipment, but with an electronic disconnect.
Old 09-21-2017, 07:39 PM   #16 (permalink)
I ran one of these on my 2011 Harley edition and really like it. Of course this was a different animal but cornering was greatly improved, always thought they should have installed one from the factory.
Heelfan1 is offline   Reply With Quote
Old 09-21-2017, 08:17 PM   #17 (permalink)
ReyLorenzo's Avatar
Looks great! Quick question about the UPR catch can install. I bought one for my 2018 and I was almost done with the install until I couldn't remove the intake pipe in order to drill and install the WOT hose. Did you have hard time taking that pipe off? I losened the clamps on both ends and I can't pull the damn thing off. Seems like it's secured to something somewhere else.
2018 Race Red - present
2014 Blue Flame - past
ReyLorenzo is offline   Reply With Quote
Old 09-22-2017, 01:15 AM   #18 (permalink)
Default Removing the Intake Tube for UPR Catch Can
Thanks. Yes, it was a tight squeeze removing the intake pipe as it's squeezed between the turbo intake pipe and a pad fastened to the right hand wheel well. I do think there are minor differences between the 2017 and 2018 Raptor intake. There were no additional fasteners holding my intake in place.
Old 09-28-2017, 03:24 PM   #19 (permalink)
Default Wiring Upfitter Switches
I plan on installing LED lights and a light bar so I decided it was best to prep the upfitter switches and wiring. I wanted to go with a quick disconnect and waterproof type connection. After some research, I settled on the Deutsch 2-pin connector housings and created my own 14 gauge ground wires.
The stock upfitter wires are short.
My ground wires assembled. I ran them all to the left bolt of the ECU.
I donít have to worry about anything shorting out and I can quickly rearrange my devices without rewiring.
Old 09-28-2017, 03:42 PM   #20 (permalink)
Nice I think I need your help lol you seem pretty handy.
Ordered a Rigid 40" midnight curved light bar for the front bumper and some of their midnight cubes for the fog pockets.
Where ats do you live? I am in Simi Valley. I am good with mounting etc but I have no clue about wiring etc and don't really want to pay a shop to do it.
Good job!
2018 Black SCREW 802A
2015 Nissan GTR FBO E85
murph145 is offline   Reply With Quote
Tags
2017 ford raptor, catch can, customization, led light, supercrew
2017 Pre Runner invasion...some footage of 2017 Ford Raptor byz250f Ford F-150 Raptor General Discussions [GEN 2] 10 05-20-2017 07:15 PM
GEN 2 2017 Ford F150 Raptor SuperCrew Getting Shipped To China - Video trev0006 Ford F-150 Raptor General Discussions [GEN 2] 9 02-04-2017 07:42 PM
Best in the Desert 2017 Ford F-150 Raptor Race Truck Chris's FX4 Ford F-150 Raptor General Discussions [GEN 2] 904 11-18-2016 12:16 PM
Used 2013 Ford F-150 SVT Raptor Truck SuperCrew Cab | Denver, CO Frogger22 Ford Raptor For Sale! 2 03-21-2016 10:54 AM
Just got my 2011 Ford Raptor SuperCrew fostercd 2011 Ford SVT Raptor Forum (Reply Only) 14 12-30-2010 12:22 AM
