Mid 2018 new metal oil pan
B
BajaFred
Don't shoot the messenger, hope someone runs with this and gets it to work
Shop installed the 2018 metal pan only to realize the 2017 oil pickup tube is a tad too long and hits the new pan
Looked up various upstream part numbers, and they are all different
Truck is a couple days away from making a long road trip, so I couldn't risk being stuck on the side of the road
It's doable, but someone needs to mod the pickup tube or see what other parts need to change to make this happen
carguyohio
This is good news. I watched a youtube video as I was curious how much needed to happen with the skid plate to change the oil. When I saw that plastic plug I was not excited.
vladi
Did you give up one the install then I take it? Or did you manage to figure out what was needed to swap to the metal oil pan?
B
BajaFred
I’m letting someone else run with the ball, I can’t risk F my engine on this road trip
kboom
Checking if I have metal or plastic oil pan
Mine is a 4/2018 build.
Vin: 1FTFW1RG4JFC88327
Where could I check what kind of an oil pan it has an other items on the build sheet?
Thanks in advance!
Kino
TXRaptor
Thanks in advance!
Kino
Do you have the truck? If so, crawl under there and see if yours is metal or plastic. Mine was built at the end of February and it has the metal oil pan.
93,171
56,440
jumpcutter
