Lug nut Torque
cmacclel
I just undercoated my rear wheel wells so I removed both rear tires and noticed the lug nuts where looser than expected. I looked them up an everyone is stating 150 ft lbs. I put the torque wrench on the fronts and they where around 100lbs from the factory.
8WOOD
you are suppose to re torque aluminum wheels after the first few thousand of miles. They settle and loosen up slightly. I think 100ft lbs is probably still good to go.
1phatstang
Kansas
Part of the required dealer pre-delivery inspection is to check the lug nut torque. The exact spec is 147 ft. lbs.
Deleted member 12951
Believe someone posted up a picture out of the owners manual that the torque is 150ft lbs on the Gen2 also.
Can you post where in the owners manual that it shows 147?
