Levelling
-Ryan-
___
I actually prefer that prerunner stance with the front a little higher. Either way, front level or slightly higher looks much better than ass high.
Get an adjustable kit, RPG, SVC, Icon and you can set it however you want.
Johngm45
I have the eibach and now I’m getting flashed all the time cb400fd0c3be9d3e5e949e360329b3ce.jpg
MGD
Banned
Why would you want the rear sagging so low? That looks absolutely terrible.
L
Lwlandy
Actually that's a good point I hadn't considered, the lights are set up from the factory so I guess if you change the stance significantly you should also get the lights re aligned.
Johngm45
I’m looking for someone to do that or knowledge on how to do it
MGD
Banned
For that amount of rear sag, there is not enough travel in the headlights to aim them low enough.
SZDZMTR
Sewell, NJ
Just wondering...at higher highway speeds the aerodynamics must be horrible. You probably get a ton of air going under the truck with the front being jacked up so high...
Johngm45
Eibach says it’s 2.5”
Going to go another setup. It rides and drives fine but only need about 2”
