Installation of Lights - 6 Aux Switches
JetDriver480
Are the 6 overhead AUX switches easily accessible under the hood for light installation into a fuse like panel?
Piranharaptor
just so you know...there are 2 sets of 6 capped off wires. total of 12. right under the hood on the left side. on mine only 6 were visible. only one set of the six are "hot" the other set go back through the firewall (so you can run stuff inside if you want)
cost me about an hour and a lot of bad words trying to figure out my I wasn't getting power. had to dig around to find the 6 hot ones.
good luck
Dr. Hunter
Do you have to connect them in the glovebox like we did in the gen 1 or are they already connected?
Piranharaptor
No. If you want something hot under the glove box you have to find the matching wire and connect it under the hood. That's the second set of 6 wires. Just remember there are 2 sets under the hood...hot set and a set that runs Back through the firewall. Different than the gen 1.
J.Bodolay
Wiring schematic shows: Up-fitter switches going directly to Battery Junction Box. Interior Switch in the "on" position will pull up the correlating relay in BJB. Energized relay will then provide you with fused power to the one of the six leads shown, located outside of the BJB.
