Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
G2 vs '18 F150 4x4 3.5
This is a discussion on G2 vs '18 F150 4x4 3.5 within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
In a previous video they did they got 6.1 0-60 in the raptor vs the 6.7 they got in this ...
Like Tree41Likes
Old 10-11-2017, 07:54 PM   #11 (permalink)
In a previous video they did they got 6.1 0-60 in the raptor vs the 6.7 they got in this video. The other video was a scab vs screw so that would put the weight closer to the standard screw.
Either configuration, they would still be close no matter the configuration. Just glad it’s two fords kicking the competitions butt.
Heelfan1 is offline   Reply With Quote
Old 10-11-2017, 08:22 PM   #12 (permalink)
These guys always have weird numbers .... they said we're averaging overall like 13.9 on their gen1 for the life of the vehicle ...... I've never seen that high on my gen 1.... ever
xBryanHoodsx is offline   Reply With Quote
Old 10-11-2017, 08:27 PM   #13 (permalink)
If they are driving at 5k ft, less dense air creates less wind resistance and also reduces output on a normally aspirated engine by about 10%. Less resistance and not being able to go "full throttle" will boost MPG.
jaz13 is offline   Reply With Quote
Old 10-11-2017, 11:02 PM   #14 (permalink)
Originally Posted by bjinc View Post
These results are a bit surprising; if you calculate the ostensible hp/weight ratios, the Raptor still has an appreciable advantage. You really have to wonder what kind of gas they were running in the Raptor (one supposes the tuned engine is more reliant on high octane gas and Colorado is known for their inferior gas), how broken-in the engines were, actual curb weights, etc, because once they got moving, you would assume the Raptor would start to walk on the F-150.
Perhaps the elevation change also impacts the Raptor more? Interesting results.
It's not just hp/weight ratio. The wheels and tires on the raptor are a lot heavier. And extra lb of rotational mass equates to a lot more than 1lb of sprung weight. I don't remember what the ratio works out to, but it makes a big difference. Add to that the greater rotational resistance of the KO2's vs street tires and its easy to see why the F150 edged out the Raptor.
I also would not be at all surprised if the F150 HP/TQ numbers are under rated. I'll bet if we put the Raptor and a 3.5EB F150 on the Dyno, the numbers will be a lot closer than it looks on paper.
Craigy and Micha like this.
jabroni619 is offline   Reply With Quote
Old 10-12-2017, 12:01 AM   #15 (permalink)
bjinc's Avatar
It is my opinion that the whole "unsprung mass" thing has always been a bit exaggerated, as least with regards to acceleration (handling is something else altogether).
Light Wheels Vs Heavy Wheels - Wheel Tech - Comparison - Car Craft - Hot Rod Network
They took off 82 pounds and gained a tenth; if you were following the ratios people spout online of 1 unsprung = 5 sprung (I've seen people say 1:10!), you'd expect an equivalent change to reducing 400 pounds, which is just not borne out by their testing. In my experience (I've had about 4 different drag cars through the years), the change in acceleration from lighter wheels and tires is practically negligible on the strip unless you're combining it with other weight reduction or power adders. I checked the weight of the tires on tire rack and the raptor tires weigh 65 pounds vs the Lariat's 39 pounds (no clue on the wheels), so I just can't agree that unsprung weight is a big factor here.
I think you're more on the nose when you suggest that the "regular" ecoboost is underrated; I think the "tuned" ecoboost in the Raptor MIGHT put out those numbers on 93 octane and with a good example of the engine, whereas the numbers on the regular F-150 are more conservative, and so the engines are much closer in power production than Ford claims.
I'm going to see if I can dig up dyno graphs of both engines, I'm very curious about it now.
bjinc is offline   Reply With Quote
Old 10-12-2017, 12:21 AM   #16 (permalink)
ranger22's Avatar
Pretty simple way to prove your theory right or wrong. Put raptor wheels/tires on a similar truck and see what happens. My money is on the Raptor.
ranger22 is offline   Reply With Quote
Old 10-12-2017, 06:32 AM   #17 (permalink)
Jake17's Avatar
gonna dig up dyno graphs of both engines, I'm very curious about it now.
someone cares
J7 801 SCab XD129
Jake17 is offline   Reply With Quote
Old 10-12-2017, 07:00 AM   #18 (permalink)
1BAD454SS's Avatar
LOL H.O. ecoboost keep drinking the $80,000 koolaid
2014 FX4 Tremor 420rwhp ,2010 Raptor 6.2L 2.9 Whipple 650 hp kit .2002 Lightning 3.4 whipple 800 RWHP, 1993 454 SS 502 ci and 2.4 kennebell, 1979 10th annivesary trans am 400 4spd ,2015 POLARIS Scrambler 1000,
1995 BANSHEE ,1985 Yamaha RZ500 4 cylinder 2stroke
1BAD454SS is online now   Reply With Quote
Old 10-12-2017, 07:22 AM   #19 (permalink)
Jake17's Avatar
Originally Posted by 1BAD454SS View Post
keep drinkin' G2 koolaid
try some
J7 801 SCab XD129
Old 10-12-2017, 07:58 AM   #20 (permalink)
ZaneMasterX's Avatar
Because 700lbs and huge tires with massive rolling resistance make no difference, right? Dont be ignorant.
ZaneMasterX is offline   Reply With Quote
2017 Ford F150 Shelby 750HP or 2018 Ford F150 Raptor? kingrichards Ford F-150 Raptor General Discussions [GEN 2] 69 06-02-2017 12:04 AM
F150 anyone ?? 6.2Canadian Garage Sale 2 03-27-2016 11:13 AM
2015 Ford F150 (and 2016 Ford F150 Raptor SVT) MagicMtnDan Ford SVT Raptor General Discussions [GEN 1] 61 01-16-2014 09:18 PM
VA guy here, All I got Is a XLT F150 Premium08 New Member Check-In 7 02-20-2013 08:09 AM
The old 92 F150 All The Way Other Vehicles 24 04-01-2012 12:00 PM
