Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Fuel pump recall
This is a discussion on Fuel pump recall within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Like Tree3Likes
Old 06-13-2018, 01:47 PM   #1 (permalink)
Default Fuel pump recall
I see there is a recall in the fuel pump. Anyone have this done yet ? Whatís the symptoms of this?
Gsteve is offline   Reply With Quote
Old 06-13-2018, 01:57 PM   #2 (permalink)
Dane's Avatar
Originally Posted by Gsteve View Post
I see there is a recall in the fuel pump. Anyone have this done yet ? What’s the symptoms of this?
Where do you see this and for what year(s)?
kboom likes this.
2012 Black SuperCrew Roush Raptor
2015 BMW S1000RR
2016 BMW S1000RR (yes, we have two)
2008 Mercedes SLK 280
2003 Jeep Rubicon (sort of)
Dane is offline   Reply With Quote
Old 06-13-2018, 02:32 PM   #3 (permalink)
Not showing anything for my vehicle on Ford Pass
jabroni619 is offline   Reply With Quote
Old 06-13-2018, 03:30 PM   #4 (permalink)
Morn's Avatar
Same here, but I found the news item that OP is talking about. It's for some 2018 F-150s and doesn't specify Raptors specifically either way.
https://www.caranddriver.com/news/fo...ial-fuel-leaks
Ford and Lincoln are recalling 7580 of its 2018 model F-150 pickups and Expedition and Navigator SUVs over a faulty fuel-pump assembly. Fuel pumps on turbocharged 3.5-liter V-6 engines might have misaligned welds, which could lead to a fuel or oil leak. Ford says it has not been notified of any accidents or injuries related to the issue.
While the number of vehicles is relatively small, this problem is not specific to one shift of workers or even one plant. It affects F-150s built in the Dearborn and Kansas City plants and Expeditions and Navigators constructed in Fordís Louisville, Kentucky, facility. Of the 7580 trucks and SUVs recalled, 5645 were built for the U.S. market, 1625 for Canada, and 310 went to Mexico.
Ford cites misaligned welds as the source of the issue. Because of this, the welds between the fuel-pump housing and the mounting flange could crack, which could result in a fuel or oil leak. Spilling oil or fuel in the engine bay could cause a fire.
To fix the problem, Ford and Lincoln will replace the components at no cost to the customer. The vehicles will be fitted with a new high-pressure fuel pump plus new pump and discharge-tube mounting bolts.
Morn is offline   Reply With Quote
Old 06-13-2018, 03:54 PM   #5 (permalink)
It’s on my ford pass
Old 06-13-2018, 04:56 PM   #6 (permalink)
Junior Member
Stupid question but what’s this ford pass?
Speedy_Thief is offline   Reply With Quote
Old 06-13-2018, 05:06 PM   #7 (permalink)
Ford Pass is an app that you can download on iOS and Android which allows you control certain functions on the truck, locate your vehicle, check mileage/fuel, and it also alerts you of any recalls if applicable.
I'm a 17' build, no fuel pump notice but have a California Emission Warranty Parts Coverage notice...
mr_beaverhousen is offline   Reply With Quote
Old 06-14-2018, 09:01 PM   #8 (permalink)
Plus remote start and door lock / unlock.
2018 Leadfoot. 802a, tech package, moon roof, beadlock, tailgate step, heated rear seats, no external graphics, interior accent, spray in liner.
Seven is offline   Reply With Quote
Old 06-15-2018, 04:48 PM   #9 (permalink)
Junior Member
got the notice on my ford pass the other day. It says Ford will send you a letter, also it might be vin specific so even if you take it in your truck it might not be required
tvvism is offline   Reply With Quote
Old 06-15-2018, 04:57 PM   #10 (permalink)
Any update on how many affected?
Birel22 is offline   Reply With Quote
Upgraded fuel pump Livernois Motorsports Livernois Motorsports 0 03-13-2018 04:20 PM
Fuel Pump?? Juanchy21MIA Ford SVT Raptor General Discussions [GEN 1] 2 05-13-2017 10:47 AM
Any known fuel pump issues after run dry? Prybar Ford Raptor Maintenance Forum 2 03-07-2017 01:51 PM
Fuel pump recall - why not apply to fuse 27? RDFTS Ford SVT Raptor General Discussions [GEN 1] 1 08-25-2016 07:30 PM
Fuel Pump Module jlauth Ford Raptor Problems and Questions Forum 3 04-14-2015 09:12 PM
