Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Front lockers available yet? Already got stuck!
This is a discussion on Front lockers available yet? Already got stuck! within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by Truckzor That is correct. Yep, I have an 801a and added the front torsen. Sent from my ...
Like Tree2Likes
Old 09-13-2017, 01:06 PM   #11 (permalink)
Originally Posted by Truckzor View Post
That is correct.
gryGhst17 is offline   Reply With Quote
Old 09-13-2017, 01:39 PM   #12 (permalink)
Originally Posted by kingshredd View Post
Do you have the Torsen front differential?
how do i make sure i do?
---------- Post added at 08:39 PM ---------- Previous post was at 08:38 PM ----------
Originally Posted by ReefBlue View Post
Sounds like you didn't get the Torsen front end.
I have the 802A package. Shouldn't that be included?
2017 Raptor
2015 Sequoia
2010 GT3
AJ-Raptor is offline   Reply With Quote
Old 09-13-2017, 02:29 PM   #13 (permalink)
Yes, so I guess it comes down to the mode the truck was in while you were driving. <shrug>
Old 09-13-2017, 02:48 PM   #14 (permalink)
kingshredd's Avatar
If the Torsen works like other limited slips, sometimes a little break pressure will get it to engage. I have Detroit TrueTracs in my 91 Toyota this is what works for them if a tire is in the air. Not sure if the different modes would effect this though.
SilverBolt likes this.
kingshredd is offline   Reply With Quote
Old 09-13-2017, 03:55 PM   #15 (permalink)
The torsen should work whenever it senses slippage, so it ought to work as long as it's in 4wd on the front. So I think your right?
Old 09-13-2017, 11:25 PM   #16 (permalink)
I haven't done much sand stuff, but is 4 LO a normal 'sand' setting?
To me 4 Lo is crawl mode, rocks, steep 'firmer' inclines, ice with chains, ice w/o chains depending on the ice and certain snow situations. Or to help you go slower when going down a steep incline.
Sand and mud I would think one would use 4 Hi and rear lockers.
Is there a way you could easily test your front torsen locker? Just wondering if something is maybe messed up/not working properly.
I know many don't like the nannies, but if they can apply slight braking pressure to the spinning wheel, may help you get out.
Gen1 vs Gen2 - Depends on the day!
2014 Black Screw, 2017 Avalanche Screw
gwpfan is offline   Reply With Quote
Old 09-14-2017, 02:31 AM   #17 (permalink)
WhatExit?'s Avatar
Did you even read the Ford factory info in the link I provided above?
Rock Crawl
This setting is for intense off-road driving and rock climbing at low speeds. Rock crawl prompts the driver to place the vehicle in 4 Low, the electronic locking differential is automatically engaged and AdvanceTrac is set to the least intrusive settings for optimum rock-climbing ability. Throttle modulation and transmission response are optimized for greater control. Additionally, the front camera allows the driver to see what’s right in front of the truck, and it can be kept on at speeds up to 15 mph.
And if you read about running in Sand you'd know that under 15MPH in Sand is a recipe for getting stuck.
If you own a Raptor please RTFM and get some practice off road using the truck's Terrain Modes.
2017 Magnetic SuperCrew Cab 802a; Raptor Tech Pkg w/Adaptive Cruise; 17" Forged Aluminum (Beadlock) Wheels; 2nd Row Heated Seats; Moonroof; Tailgate Step; Exterior & Hood Graphics Pkgs (both removed); Carbon Fiber Pkg; Engine Block Heater. Added: new V1; BlendMount; XPEL Ultimate & Stealth Film; Tinted Front Windows; BedRug, Roll-N-Lock A-Series bed cover
WhatExit? is offline   Reply With Quote
Old 09-14-2017, 10:44 AM   #18 (permalink)
Damn, quick to pull the trigger. I read what you put and also RTFM.
Also read the manual on my 12' F150 that said no chains/chains not recommended with the tire and wheel setup I had. Guess what, chains fit fine if tight and traveling at a lower speed, which on ice w/chains one typically does.
Point being TFM doesn't cover every instance along with me stating I haven't ran in sand...did you read MFP? ;o)
Maybe you missed the OP said they were running in sand in 4 LO, or were easier on them!!!!!
(I got stuck today in an attempt to clear a large sand barricade diagonally when the truck was almost balancing on its belly with rear tires digging freely in the sand and one front tire almost in the air and the second with good traction but no power sent to it. I was in rock crowing mode so 4x4 Lo with rear diff lock.
AJ-Raptor likes this.
Old 09-14-2017, 11:14 AM   #19 (permalink)
I think the truck applies limited-slip braking to the spinning wheels in a traditional tracktion control way, but that might be disabled in the offroad modes.
jaz13 is offline   Reply With Quote
Old 09-14-2017, 10:51 PM   #20 (permalink)
Traction control is NOT disabled in off road modes. It differs a little in how much tire slippage it will allow, but it's definitely active. If you want it off, you have to turn it off.
2017 Magnetic SCREW
802a luxury package | technology package | twin panel roof | tailgate step | heated steering wheel | 2nd row heated seats | spray in bed-liner
CFIT is offline   Reply With Quote
Tags
front, locker, lockers
Help!!! Differential Questions: Gears, Lockers, and Diff covers Front and Rear! ISFast Ford Raptor Problems and Questions Forum 59 01-12-2017 05:29 PM
Stuck it! Evilmonkey Ford Raptor Photos & Videos 15 05-20-2013 09:14 PM
First Stuck! Bink1109 Ford SVT Raptor General Discussions [GEN 1] 13 05-14-2013 11:53 PM
got stuck Netix Off-Roading Your Raptor 13 10-02-2012 12:38 PM
