Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Forscan - DRL not working
This is a discussion on Forscan - DRL not working within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
I have always had good luck making changes with Forscan. Everything was great until I took the truck in for ...
Old 09-21-2017, 10:27 AM   #1 (permalink)
thetasigma1186's Avatar
Default Forscan - DRL not working
I have always had good luck making changes with Forscan. Everything was great until I took the truck in for an oil change/maintenance. Now the LED DRLs are not coming on. I had it set so the LEDs and Turns stayed on.
Has anyone had any issues with this? All my other changes seem to have stuck. I have attached my BCM module if someone can look at it. Thank you!
~Matt
bcm.pdf
thetasigma1186 is offline   Reply With Quote
Old 09-21-2017, 11:25 AM   #2 (permalink)
RAPTERRIER's Avatar
With my truck and after doing Forscan, the DRL's only work when in gear.
'17 802A AV Gray
Gen II Deplorable
RAPTERRIER is offline   Reply With Quote
Old 09-21-2017, 12:04 PM   #3 (permalink)
I do have the truck in gear...but still not working. Not sure what else to check.
Old 09-21-2017, 04:06 PM   #4 (permalink)
Big Johnson's Avatar
Wth cluster controlled drl's I think you need to have the headlight switch in auto
Big Johnson is offline   Reply With Quote
Old 09-21-2017, 04:18 PM   #5 (permalink)
Banned
I bet the dealer reflashed your pcm with the latest and greatest program while in for service. You may have to redo your programming.
Mcnawsty is offline   Reply With Quote
Old 09-21-2017, 05:02 PM   #6 (permalink)
crash457's Avatar
I'm Batman
Did you check to make sure the DRLs are still turned on in the vehicle settings (ICP display)?
2017 Ruby Red SCREW 802A-Ordered 8/3, Built 10/14, Released from Factory 12/12, Accepted by Shipping Company 12/27, Delivered 1/19
crash457 is offline   Reply With Quote
Old 09-21-2017, 05:11 PM   #7 (permalink)
I do have the switch to auto...but I think it was off last night when I first noticed it.
I may have fixed it! Not sure how...but it is working now. BUT, I inadvertently enabled the TURNS and I only wanted to U-bar LED. Does anyone know the default for line 726-45-01? I lost my as-built backups.
Thanks!
Old 09-21-2017, 09:55 PM   #8 (permalink)
AvoidTheBoyd's Avatar
Thanks!
I think this should be stock for 726-45-01. 0A0011010190
---------- Post added at 07:55 PM ---------- Previous post was at 07:51 PM ----------
I think that is normal all the time, Forscan or not. It was for me.
2017 Magnetic Screw 802A
AvoidTheBoyd is offline   Reply With Quote
FORScan on a Gen1 t_j Ford Raptor Audio/Video/Electronics Forum [GEN 1] 64 01-05-2018 08:42 PM
FORSCAN help? chattermark Ford F-150 Raptor General Discussions [GEN 2] 10 11-06-2017 10:21 PM
Forscan Question DANACO Ford F-150 Raptor General Discussions [GEN 2] 0 09-08-2017 07:35 AM
GEN 2 Forscan Help Jayrod Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 2 07-13-2017 10:55 PM
GEN 1 2011 SCREW window switches stop working, then start working after power off Blu808 Ford Raptor Problems and Questions Forum 5 01-19-2017 06:31 PM
