Forscan - DRL not working
thetasigma1186
Clever, MO
I have always had good luck making changes with Forscan. Everything was great until I took the truck in for an oil change/maintenance. Now the LED DRLs are not coming on. I had it set so the LEDs and Turns stayed on.
Has anyone had any issues with this? All my other changes seem to have stuck. I have attached my BCM module if someone can look at it. Thank you!
~Matt
  • BCM.pdf
RAPTERRIER
Full Access On Your Mom
With my truck and after doing Forscan, the DRL's only work when in gear.
Mcnawsty
Banned
I bet the dealer reflashed your pcm with the latest and greatest program while in for service. You may have to redo your programming.
crash457
I'm Batman
St. Louis, MO
Did you check to make sure the DRLs are still turned on in the vehicle settings (ICP display)?
thetasigma1186
thetasigma1186
Clever, MO
Wth cluster controlled drl's I think you need to have the headlight switch in auto
I do have the switch to auto...but I think it was off last night when I first noticed it.
I may have fixed it! Not sure how...but it is working now. BUT, I inadvertently enabled the TURNS and I only wanted to U-bar LED. Does anyone know the default for line 726-45-01? I lost my as-built backups. :emotions122:
Thanks!
AvoidTheBoyd
Wisconsin
Thanks!
I think this should be stock for 726-45-01. 0A0011010190
---------- Post added at 07:55 PM ---------- Previous post was at 07:51 PM ----------
I think that is normal all the time, Forscan or not. It was for me.
