Forscan changes - tweak your truck
xxaarraa
Southlake, TX
Hey I found this setting. Turned off interior sensors and also disabled "ask on exit"
Thanks for the tip!
So funny to keep discovering new options and features on this truck. The other day I found that I have adjustable pedals for the first time! lol. I was like "hey what does this button do? damn it moves the pedals!"
OK I am sorry to report that this setting resets every time the vehicle is turned off.
I'm going to do just what Liv suggested - tape up the interior sensors.
Rapterzz
Mine does not you have to do it thru the settings
Grizlbits
Is it possible through Forscan to have the heated seats or heated steering wheel come back on after restarting the vehicle?
I did a bunch of the common changes to my truck and it all works great. I'm bringing this post back up because I never saw a response on this one. I would like the seats (and wheel) to start back with the last command. I always forget to turn on the seats until halfway home. My 2017 Explorer does this just fine, the Raptor not so much.
Anyone find out how to get the seats to come back on to the last setting?
Thanks
xxaarraa
Southlake, TX
Thanks
If you remote start the vehicle, I believe the heated/cooled seats will go back to previous setting. I saw an option in advanced settings that said so. In fact, it also asked if you wanted them to go back to previous setting or to "Auto" as in, it determines where to set them based on ambient/exterior temps.
halogrinder
My buddies 2011 EB was over at the shop and I tried to do some coding on it- it didn't respond to really, anything. Bambi mode, sync changes- nothing. seemed wierd.
Livnitup
SoCal
The modules & addresses on previous generation trucks are very different and you shouldn't try any listed FORScan changes for the '15-'17s on it. Most of what the 2015-2017s can do, the prior years can't.
If you do want to try some things for his '11 then use values listed on this spreadsheet which should cover that generation:
https://docs.google.com/spreadsheet...vHJXZPBfqJs94JIf45c7X2zgg/edit#gid=1329872825
hmgt3
Just parking lights as DRL. If you want both low beams & parking lights as DRL just make this change:
726-26-02x1xxxxxxxxxx
For only parking lights as DRL just do the following (I edited my other post):
726-50-01017F
Hi. Will this turn on the rear lights on too? Or just the fronts?
Sent from my G8142 using Tapatalk
