southof30A
Anyone had any luck getting Ford Dealer to work to reduce turbo lag and improve throttle response as a warranty repair issue?
LOLI haven't been there that long, but I'd have to imagine this is at or near the very top of the dumbest things ever asked on FRF
Have you tried the throttle reset procedure? There are instructions floating around somewhere, but it is just cycling the ignition a few times and moving the gas pedal. The result is the new end parameters on the accelerator travel are relearned. In normal driving, the electronics sense the travel of day to day use and it thinks the travel is less than it is. This is a good reset to do monthly. The ecoboost is especially sensitive to this since it relies heavily on boost to get it to go anywhere.
You just need to make sure your turbo increaser is turned on. There's a button in the back passenger seat glove box.
