Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
DIY Tire Rotation (TPMS problems?)
This is a discussion on DIY Tire Rotation (TPMS problems?) within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
About ready to rotate my tires since I have about 4k on the truck now. Can I just rotate them ...
Like Tree17Likes
Old 07-12-2018, 10:29 AM   #1 (permalink)
ChevyChad's Avatar
Default DIY Tire Rotation (TPMS problems?)
About ready to rotate my tires since I have about 4k on the truck now. Can I just rotate them and call it a day? Or will that throw off the TPMS system? If the sensors need to be re-learned for the new location, is there any way I can do that myself?
2018 Leadfoot SCREW- 802A, tech package, stock for now
2017 Lightning Blue SCREW (Sold)- 802A, tech package, carbon fiber, moon roof, Fab Fours Vengeance Pre-Runner front bumper with lots of LEDs, 20x9 Fuel Vapor wheels with 37x12.5 Nitto Ridge Grappler tires, Icon 2.25" front level, Line-X bed spray, tinted windows, retractable bed cover
ChevyChad is offline   Reply With Quote
Old 07-12-2018, 10:33 AM   #2 (permalink)
Robtor310's Avatar
Dont Feed the Trolls
Youll need to do a re learn. Super easy.
Put in accessory mode. Dont start the truck.
Turn the hazard flashers on then off three times. You must accomplish this within 10 seconds. If the reset mode has been entered successfully, the horn
will sound once, the system indicator will flash and a message is shown in the information display. It should prompt you to the Left Front
Remove the valve cap from the valve stem on the left front tire. Decrease the air pressure until the horn sounds. Note: The single horn chirp confirms
that the sensor identification code has been learned by the module for this position. If a double horn is heard, the reset procedure was unsuccessful, and
you must repeat it.
Train the tire pressure monitoring system sensors in the tires using the following system reset sequence starting with the left front tire in the following clockwise order: Left front (driver's side front tire), Right front (passenger's side front tire), Right rear (passenger's side rear tire), Left rear (driver's side rear tire).
Remove the valve cap from the valve stem on the right front tire. Decrease the air pressure until the horn sounds.
Remove the valve cap from the valve stem on the right rear tire. Decrease the air pressure until the horn sounds.
Remove the valve cap from the valve stem on the left rear tire. Decrease the air pressure until the horn sounds. Training is complete after the horn sounds for the last tire trained
Theres some type of tool too but this is easy enough that I never found the need to buy it.
17 SCABALANCHE 802A 5-31-17 Build
Method | Baja Designs S8/S2/Squads | RPG Stage 3 w +2 Deaver, RPG 1.5" Collars | Icom 880H | Lowrance | Ford Performance Diff Cover | V1 Radar | LineX | BakFlip F1
Robtor310 is offline   Reply With Quote
Old 07-12-2018, 10:48 AM   #3 (permalink)
ChevyChad's Avatar
Thanks for that, Robtor310. My tires are filled with nitrogen though (dealer did it to all their raptors they had on the lot), so I'd hate to drain too much air out of them because its not something I can refill myself. Any idea how much air needs to be drained per tire for this method to work? If its more than 1psi or so, any idea where to get the tool?
Old 07-12-2018, 10:56 AM   #4 (permalink)
brettmess24's Avatar
I didnít have to do a thing when I rotated mine.
dannym2009 likes this.
___________________________________________
2018 Black SuperCrew
2014 Black SuperCrew
2011 Black SuperCab
brettmess24 is offline   Reply With Quote
Old 07-12-2018, 11:34 AM   #5 (permalink)
Jake17's Avatar
Originally Posted by ChevyChad View Post
Ready to rotate tires...can I rotate them & call it a day?
My tires are filled with dealer nitrogen.
smurfslayer. likes this.
J7 801 SCab XD129
Jake17 is offline   Reply With Quote
Old 07-12-2018, 11:36 AM   #6 (permalink)
Robtor310's Avatar
If I had to guess I think its around 5psi.
The tool is something like this.
https://www.amazon.com/Motorcraft-TP.../dp/B001FKSNUI
I cannot vouch for it though. May have to do some more research.
Originally Posted by brettmess24 View Post
I didn’t have to do a thing when I rotated mine.
Technically you dont have to do anything. You wont get a warning or error. Your tires/TPMS wont be synced with the locations in the gauge cluster display. Thats all.
ChevyChad likes this.
Old 07-12-2018, 11:47 AM   #7 (permalink)
If you don't mine your instrument cluster not correlating tire pressures with the correct tires, you don't have to do anything.
Robtor310 likes this.
jabroni619 is offline   Reply With Quote
Old 07-12-2018, 11:49 AM   #8 (permalink)
trophycummins's Avatar
The truck will auto program most of the time. Just by driving it down the road. The relearn procedure is rarely needed.
I recommend buying the TPMS 35 tool. Its very easy to use.
Tim @ Galpin Auto Sports - Los Angeles, CA
95 Ford Bronco w/ Solo motorsports long travel and cage in progress.
2017 F150 With Mid Travel and King 3.0 coilovers/bypasses. SVC Bypass rack/King bumps/Deavers/shackles.
trophycummins is offline   Reply With Quote
Old 07-12-2018, 11:51 AM   #9 (permalink)
Mine absolutely are in the right location as I run a lower PSI in the rear than the front. I must have the advanced tpms
I have to use the tool on our chev suburban for location but Iím positive my Raptor self learns really quick on the location of each tpm. Iím sure your process makes the location instant as I have done the same in the past. Could be that I air up the fronts and deflate the rear by 2psi. Ymmv
2011 Black SuperCab
Old 07-12-2018, 11:57 AM   #10 (permalink)
Robtor310's Avatar
Good to know!
GEN 2 Tire Rotation aalonso Ford F-150 Raptor General Discussions [GEN 2] 22 06-14-2018 10:57 AM
TPMS and tire rotation questions OrangeAddict Ford Raptor Wheels & Tires Forum [GEN 1] 14 11-26-2014 11:26 AM
Tire problem after rotation OrangeTiger Ford Raptor Maintenance Forum 13 08-16-2014 03:51 PM
Tire rotation mfrunlimited Ford Raptor Maintenance Forum 18 10-29-2013 11:07 AM
What's Ford Charging You for a LOF and Tire Rotation? BigJ Ford Raptor Maintenance Forum 18 04-14-2010 05:57 PM
