Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Detailed tech specs on Raptor?
This is a discussion on Detailed tech specs on Raptor? within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Just bought a 2018 Raptor yesterday after owning 5 Super Duty pickups. What I'm looking for is detailed info on ...
Like Tree1Likes
  • 1 Post By troverman
Old 09-08-2017, 10:14 AM   #1 (permalink)
Default Detailed tech specs on Raptor?
What I'm looking for is detailed info on the Raptor. I want to know more info on what is different between the Raptor 3.5L and the pickup 3.5L. Any transmission differences? The transfer case...is the "4A" function the same as it would be on a Lariat F-150? I realize the 4H and 4L modes physically lock (kind of like the transfer case in an XL or XLT F-150 which don't have the 4A mode). Anything beyond that? Is the low ratio the same 2.64:1 as an F-150?
I'd like info on the frame differences. I understand the Raptor has a unique frame. Is it essentially an F-150 frame with some thicker sections?
I've read the rear axle on the Raptor is 35 spline whereas on the F-150 it is not. Are the axles physically wider? Is the front diff / axle the same?
How many amps is the alternator? 220A like an F-150?
Thanks in advance
2018 Ford Raptor Crew 800A - Leadfoot
troverman is offline   Reply With Quote
Old 09-08-2017, 11:09 AM   #2 (permalink)
Some of the info you're looking for is in this video, I think: https://www.youtube.com/watch?v=it54X_huF0w
Life is hard; it's harder if you're stupid - Anonymous
Follow your dreams... unless you're a pedophile - Bill Burr
BurnOut is offline   Reply With Quote
Old 09-08-2017, 12:01 PM   #3 (permalink)
Thanks for the link, BurnOut.
What I gleaned was the following:
-Frame difference is limited to shock mounts (+50% stronger rear and +25% stronger front plus higher mounting location for both) and additional weldments for strength. Otherwise, the frame is an F-150 frame.
-Axles are the same except the rear axle uses 35 spline axle half-shafts compared to standard F-150 shafts.
-Front hood and fenders are composite. Knew the fenders were; did not know the hood was.
-The HO 3.5L EB uses larger turbos with a little higher boost plus electronically controlled wastegates instead of pressure-controlled. The engine uses dual electric fans instead of the single electric fan on standard F-150 EB motors. The 2-piece oil pan and "low structure" is unique to the Raptor.
weezy likes this.
Old 09-08-2017, 01:40 PM   #4 (permalink)
SilverBolt's Avatar
Hired Gun
Most F-150's have the 8.8" rearend the Raptor is 9.75".
2012 Toyota FJ Cruiser
2018 Raptor Screw 802A White
SilverBolt is offline   Reply With Quote
Raptor Assault - Detailed Course Overview JetDriver480 Ford F-150 Raptor General Discussions [GEN 2] 77 02-14-2018 10:21 PM
Detailed 2017 Raptor crash457 Ford Raptor Cleaning and Detailing Forum 13 03-01-2017 12:54 AM
Here are the Raptor engine specs... Lightman Ford F-150 Raptor General Discussions [GEN 2] 201 09-29-2016 08:10 PM
Specs on this Raptor? BlackReef Ford Raptor Build-Up Forum 13 07-22-2013 09:26 AM
New Detailed Pics of the 2011 Raptor Hood and Digital Mud Graphics BigJ Ford Articles, News and Media Reviews 20 09-11-2010 07:29 PM
